Mexico Voice Issue - phone continues to ring after disconnect
Yort Mantup
Level 4
Level 4
I am working with 4 telmex lines that are connected to FXO ports on a Cisco 2811 Router (12.4).   When calls ring into any of the lines and is hung up on the other end before it is answered.  The phone continues to ring and often a new voicemail is left because the call never disconnects.
This is my first experience with voice in Mexico.  I did some research and came up with the following configs.  However the issue still remains.  I do not believe I have the correct cadence and frequency settings.  Does anyone know what these should be?
voice class custom-cptone FXO
dualtone disconnect
  frequency 427 497
  cadence 230 540
voice-port 0/1/3
supervisory disconnect dualtone mid-call
supervisory custom-cptone FXO
no comfort-noise
cptone MX
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 50
caller-id enable
7 Replies 7
Yort Mantup
Level 4
Level 4
Discovered my issue.  The fix was changing the frequency and cadence to
frequency 420 430
  cadence 319 319
shut/no shut the ports and tested.  Phone rings only once after the call is hung which is a huge improvement.
Excelente Respuesta !!!
Esa es la cadencia y frecuencia para las lineas de Telmex,
La tengo funcionando en un Router CISCO2901/K9 con este IOS c2900-universalk9-mz.SPA.151-4.M4.bin
Version 15.1(4)M4
FXO port dont know the diconnect frequency used in pstn line. we solve this issue by capturing the parameters( frequency and cadence)
create a custom cptone using the command ' voice class custom-cptone '
using this command we can customize disconnect tone,busy tone,pstn line parameter
voice class custom-cptone magicJack
dualtone disconnect
frequency 480 620
cadence 255 255 255
voice-port 0/3/0
supervisory custom-cptone magicJack
timeouts call-disconnect 2
timing hookflash-out 500
connection plar opx 5551000
caller-id enable
use this also :
http://www.3amsystems.com/wireline/tone-search.htm?
i think this wil help you
please rate if this will help ,
I have the same problema with telmex
Must be 425 Hz 250 on 250 off for busy tone. But récorded a call and check with audacity and found 425@-11 and 300 ms on 300 ms off
Br
Alan Chavira
jordrodr
This's worked for me, my TELCO provider is AXTEL, and this was the voice class TAC found out:
voice class custom-cptone CPTONE-AXTEL
dualtone disconnect
  frequency 425
  cadence 510 510
There were some other commands added to the voice ports, although I'm not sure what they are for:
voice-port 0/2/0
supervisory custom-cptone CPTONE-AXTEL
timeouts call-disconnect 3
timeouts wait-release 3
timing guard-out 1000
I hope someone can explain their use when they are applied to FXO ports.
Gracias  jordrodr,Para mi fue util, las llamadas que entraban por una FXO con llinea de axtel y se desviaban hacia la PSNT de axtel por otro FXO no se estaban desconectando.
