MGCP FXO Gateway on 2811 Router
Hi Guys,
I have a 2811 ISR router. I want to configure MGCP PSTN gateway on FXO port. here i am mentioning the ios details:
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
is this fine for mgcp pstn configuration or shall i upgrade this software for support and future issues like ringing issue/call disconnection issue. kindly suggest
Thanks in Advance,
Nisar KP
cnuche
The IOS is fine, you can configure MGCP on that, here are a couple of docs for that, they are a bit old, but still apply.
Configuring the Cisco IOS MGCP Gateway
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/42105-vg200-cfg.html
Configure MGCP Gateway and FXO/FXS Ports on a Cisco CallManager Server
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/42101-cm-cfg.html#tasks4x
Finally here you can check the official and tested IOS versions for the main CUCM versions>
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
Christian.
cnuche
Christian.
