09-22-2022 08:54 AM
We have a weird issue going on. We configured a VG202 for testing purposes. Configured in CUCM with MGCP, endpoints are registered and everythign. MGCP shows active. When testing the FXO ports, we keep getting fast busy. I've captured some debugs, and it's odd that I don't see a calling or called number
*Mar 1 00:53:44.503: MGCP Packet sent to 10.105.36.4:2427--->
NTFY 810154413 *@ch-1510-voice-analog.co.phillong.com MGCP 0.1
X: 0
O:
*Mar 1 00:53:44.503: MGCP Packet received from 10.105.36.4:2427--->
200 810154413
*Mar 1 00:53:46.799: htsp_process_event: [0/0, FXSLS_ONHOOK, E_DSP_SIG_1100]fxsls_onhook_offhook htsp_setup_ind
*Mar 1 00:53:46.799: [0/0] get_local_station_id calling num= calling name= calling time=03/01 00:53 orig called=
*Mar 1 00:53:46.803: //-1/9EEF51288002/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Mar 1 00:53:46.803: //-1/9EEF51288002/CCAPI/cc_api_call_setup_ind_common:
Interface=0x8450CB24, Call Info(
Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=99900, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Mar 1 00:53:46.803: //-1/9EEF51288002/CCAPI/ccCheckClipClir:
In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Mar 1 00:53:46.807: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 1 00:53:46.807: :cc_get_feature_vsa malloc success
*Mar 1 00:53:46.807: cc_get_feature_vsa count is 1
*Mar 1 00:53:46.807: :FEATURE_VSA attributes are: feature_name:0,feature_time:2200650592,feature_id:1
*Mar 1 00:53:46.807: //1/9EEF51288002/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
*Mar 1 00:53:46.807: //1/9EEF51288002/CCAPI/cc_process_call_setup_ind:
Event=0x844EABE0
>>>>CCAPI handed cid 1 with tag 99900 to app "MGCPAPP"
*Mar 1 00:53:46.807: //1/9EEF51288002/CCAPI/ccCallSetContext:
Context=0x84804D08
*Mar 1 00:53:46.807: //1/9EEF51288002/CCAPI/ccCallSetupAck:
Call Id=1
*Mar 1 00:53:46.807: //1/9EEF51288002/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
*Mar 1 00:53:46.807: //1/9EEF51288002/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x0
Call Entry(Connected=TRUE, Responsed=TRUE)
*Mar 1 00:53:46.811: MGCP Packet sent to 10.105.36.4:2427--->
NTFY 810154414 aaln/S0/0@ch-1510-voice-analog.co.phillong.com MGCP 0.1
N: ca@10.105.36.4:2427
X: 2
O: L/hd
*Mar 1 00:53:46.811: htsp_process_event: [0/0, FXSLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]fxsls_check_auto_call
*Mar 1 00:53:46.815: htsp_process_event: [0/0, FXSLS_OFFHOOK, E_HTSP_CONNECT]fxsls_offhook_connect
*Mar 1 00:53:46.815: [0/0] set signal state = 0x6 timestamp = 0
*Mar 1 00:53:46.815: MGCP Packet received from 10.105.36.4:2427--->
200 810154414
RQNT 261 AALN/S0/0@ch-1510-voice-analog.co.phillong.com MGCP 0.1
X: 3
R: L/hu
S: T/ro
Q: process,loop
*Mar 1 00:53:46.815: //1/9EEF51288002/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Fast Busy,
Tone Direction=Network, Params=0x0, Call Id=1
*Mar 1 00:53:46.819: MGCP Packet sent to 10.105.36.4:2427--->
200 261 OK
Any assistance would be appreciated! Thank you so much!
09-22-2022 09:14 AM
You cannot connect end point on FXO ports. These ports are for connecting telco lines.
Can you explain a little more about your setup. and i dont recommend using MGCP with FXO.
10-05-2022 01:37 PM
Sorry! We got it figured out, thank you for the reply!
