MGCP Gateway and CUCM problem.
I have CUCM 7.1.4 and remote IOS MGCP Gateway, connected via E1 to PBX.
Everything works fine untill WAN link temporarily fails. After link recovers, MGCP gateway stops working.
# sho mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 10.96.36.2 2427 Initial protocol service is MGCP 0.1
CUCM show what gateway is registered okay, but calls get rejected.
Call tracing revealed this message:
05/23/2011 09:58:56.220 CCM|ConnectionManager - wait_AuDisconnectRequest ERROR:NO ENTRY FOUND IN TABLE,CI(18054240,0),dcType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)|<CLID::StandAloneCluster><NID::10.96.36.2><CT::1,100,39,1.49539036><IP::10.96.41.18><DEV::SEP1C17D3404C98><LVL::Error><MASK::0800>
issuing
(config)# no mgcp
(config)# mgcp
fixes problem untill next WAN failure
trace log attached
Call made at 09:58:55.959
calling number 8489
called number 0040
11 Replies 11
paolo bevilacqua
Switch to H.323 or SIP, you will enjoy more features and less trouble,
Yeah.
Then switch to Asterisk.
Very wrong analogy, get informed before talking.
Tim Smith
Level 4
Level 4
What version of IOS you running?
There have been bugs that affect fail back to MGCP after a switchover.
Have you done a search on the cisco.com bug toolkit?
Cheers,
Tim
Cheers,
Tim
Tried different versions. Right now it's Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T5, RELEASE SOFTWARE (fc3). Router 2811.
Ok so quite recent.
What about your IOS configuration?
If there's nothing obvious, then your best bet would be a TAC case.
I also agree that H.323 and SIP are usually nicer, but obviously that's a design change. And MGCP should work - it does normally switch back automatically!
However - 1 point to consider is call preservation. You'll drop all your calls when switching call control from MGCP to local in SRST mode. Not a good look normally.
Cheers,
Tim
Call preservation is really the lesser of H.323 advantages - as it requires the non TAC supported  disabling of H.225 keepalives.
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_configuration_guide_chapter09186a00806674d2.html
The real advantages are actually others, robustness, flexibility, serviceability, config cleanliness, call blocking, TCL/ICR script support, and some more.
All by the book.
(config)#  ccm-manager config server x.x.x.x
I did already. They took time to investigate.
I'd prefer to try and fix problem first. Having centralized management is one of reasons we've spent a fortune bying CUCM.
Ultair,
Did you ever get this resolved?  We are having the same issue with our MGCP not recovering too.
CCM - System version: 8.6.2.20000-2
2811 Router - Version 12.4(24)T6
Thanks!!
No, switched to SIP. Easy to debug, easy to trace.
