MGCP Gateway no registering with CUCM 8.0.2
elliotfoley
I hope someone can help me. I've scoured the forums and support documents but can't seem to determine why my 1760-V Gateway won't register correctly with my CUCM 8.0.2 running on VMWare. From my reading it looks as if they are communicating with each other but just doesn't seem to register properly. Or whether it has in fact and I'm just being stupid. Your help is greatly appreciated
Voice-GW#sh version
Cisco IOS Software, C1700 Software (C1700-IPVOICE-M), Version 12.3(11)T11, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 24-Aug-06 15:54 by dchih
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
Voice-GW uptime is 5 hours, 7 minutes
System restarted at 09:28:14 UTC Thu Oct 18 2012
System image file is "flash:c1700-ipvoice-mz.123-11.T11.bin"
Cisco 1760 (MPC860P) processor (revision 0x600) with 114981K/16091K bytes of memory.
Processor board ID FOC09271DDE (1411088033), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 Ethernet interface
1 FastEthernet interface
2 Voice FXO interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Voice-GW#sh run | i ip domain
Voice-GW#
Voice-GW#sh ccm-manager
MGCP Domain Name: Voice-GW
Priority        Status                   Host
Primary         Registered               172.16.1.101
First Backup    None
Second Backup   None
Current active Call Manager:    172.16.1.101
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            14:54:34 UTC Oct 18 2012 (elapsed time: 00:00:05)
Last MGCP traffic time:         14:54:34 UTC Oct 18 2012 (elapsed time: 00:00:05)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
Configuration Auto-Download Information
No configurations downloaded
Current state: Waiting for commands
Configuration Download statistics:
        Download Attempted             : 2
          Download Successful          : 2
          Download Failed              : 0
        Configuration Attempted        : 1
          Configuration Successful     : 0
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 1
Last config download command:
Configuration Error History:
voice-port 2/0signal loopStart
FAX mode: cisco
Voice-GW#sh mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 172.16.1.101 2427 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay for VoIP is SDP controlled
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough disabled
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled.
MGCP TSE payload: 100
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP rtp unreachable timeout 1000 action notify
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
MGCP persistent offhook: ENABLED, MGCP persistent onhook: DISABLED
MGCP piggyback msg ENABLED, MGCP endpoint offset DISABLED
MGCP simple-sdp ENABLED
MGCP undotted-notation DISABLED
MGCP codec type g711ulaw, MGCP packetization period 20
MGCP JB threshold lwm 30, MGCP JB threshold hwm 150
MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300
MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000
MGCP CL threshold lwm 1000, MGCP CL threshold hwm 10000
MGCP playout mode is adaptive 60, 40, 200 in msec
MGCP Fax Playout Buffer is 300 in msec
MGCP media (RTP) dscp: ef, MGCP signaling dscp: af31
MGCP default package: line-package
MGCP supported packages: gm-package dtmf-package trunk-package line-package
                         hs-package rtp-package ms-package dt-package mt-package
                         sst-package
MGCP Digit Map matching order: shortest match
SGCP Digit Map matching order: always left-to-right
MGCP VoAAL2 ignore-lco-codec DISABLED
MGCP T.38 Max Fax Rate is DEFAULT
MGCP T.38 Fax is DISABLED
MGCP T.38 Fax ECM is ENABLED
MGCP T.38 Fax NSF Override is DISABLED
MGCP T.38 Fax Low Speed Redundancy: 0
MGCP T.38 Fax High Speed Redundancy: 0
MGCP control bind :DISABLED
MGCP media bind :DISABLED
MGCP Upspeed payload type for G711ulaw: 0,  G711alaw: 8
MGCP Static payload type for G.726-16K codec
MGCP Dynamic payload type for G.726-24K codec
MGCP Dynamic payload type for G.Clear codec
MGCP Guaranteed scheduler time is disabled
Voice-GW#sh mgcp endpoint
Voice-GW#
Voice-GW#sh mgcp connection
Voice-GW#
Voice-GW#sh diag
Slot 0:
        C1760 1FE VE 4SLOT DV Mainboard Port adapter, 4 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware Revision        : 6.0
        PCB Serial Number        : FOC09271DDE
        Part Number              : 73-7167-06
        Board Revision           : A0
        Fab Version              : 04
        Product (FRU) Number     : CISCO1760
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 03 16 41 06 00 C1 8B 46 4F 43 30 39 32
          0x10: 37 31 44 44 45 82 49 1B FF 06 42 41 30 02 04 FF
          0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Packet Voice DSP Module Slot 0:
        Hardware Revision        : 3.2
        Part Number              : 73-6726-01
        Board Revision           : A0
        Deviation Number         : 0-0
        Fab Version              : 03
        PCB Serial Number        : ICP0548003M
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 02
        Number of DSP's          : 1
        DSP memory size(in kwords): 256
        Type of DSP              : TMS320C549
        Product (FRU) Number     : PVDM-256K-4=
        0x00:   04 FF 40 02 AC 41 03 02 82 49 1A 46 01 42 41 30
        0x10:   80 00 00 00 00 02 03 C1 8B 49 43 50 30 35 34 38
        0x20:   30 30 33 4D 03 00 81 00 00 00 00 04 00 09 02 FF
        Packet Voice DSP Module Slot 1:
        Not populated
        WIC/VIC Slot 1:
        Ethernet 10bT
        Daughter card-Version 4 TLV Cookie Format
        Hardware Revision        : 3.0
        Part Number              : 73-5797-03
        Board Revision           : A0
        Fab Version              : 02
        PCB Serial Number        : FOC09080GYR
        RMA History              : 00
        Top Assy. Part Number    : 800-09311-03
        Connector Type           : 01
        Chassis MAC Address      : 0004.8d0c.ea06
        Number of Slots          : 255
        Product (FRU) Number     : WIC-1ENET=
        VIC Slot 2:
        Dual FXO EU Voice Interface Card
        Hardware revision 1.0   Board revision B0
        Serial number     0027306996    Part number    800-03639-03
        FRU Part Number   VIC-2FXO-EU=
        Test history      0x00          RMA number     00-00-00
        Connector type    WAN Module
        EEPROM format version 1
        0x20:   01 16 01 00 01 A0 AB F4 50 0E 37 03 00 00 00 00
        0x30:   58 00 00 00 02 01 04 01 FF FF FF FF FF FF FF FF
#sh voice port 2/0
Foreign Exchange Office EU 2/0 Slot is 0, Sub-unit is 2, Port is 0
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 64 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 250 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is enabled
Number Of Rings is set to 1
Supervisory Disconnect is signal
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Out Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 60 percent
GuardOut timer is 2000 ms
Minimum ring duration timer is 125 ms
Hookflash-in Timing is set to 600 ms
Hookflash-out Timing is set to 400 ms
Supervisory Disconnnct Timing is set to 350 ms
Voice-GW#sh mgcp statistics
UDP pkts rx 879, tx 937
Unrecognized rx pkts 0, MGCP message parsing errors 0
Duplicate MGCP ack tx 0, Invalid versions count 0
CreateConn rx 0, successful 0, failed 0
DeleteConn rx 0, successful 0, failed 0
ModifyConn rx 0, successful 0, failed 0
DeleteConn tx 0, successful 0, failed 0
NotifyRequest rx 19, successful 0, failed 19
AuditConnection rx 0, successful 0, failed 0
AuditEndpoint rx 19, successful 0, failed 19
RestartInProgress tx 445, successful 445, failed 0
Notify tx 405, successful 405, failed 0
ACK tx 0, NACK tx 38
ACK rx 434, NACK rx 407
IP address based Call Agents statistics:
IP address 172.16.1.101, Total msg rx 402,
                  successful 374, failed 28
System resource check is DISABLED. No available statistic
DS0 Resource Statistics
Utilization: 0.00 percent
Total channels: 0
Addressable channels: 0
Inuse channels: 0
Disabled channels: 0
Free channels: 0
Once again thanks for your help in advance
2 Accepted Solutions
Elliot,
Your IOS is older so you need to use
dial-peer voice 100 pots
port 2/0
application mgcpapp
no mgcp
mgcp
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Agree with Alex, I missed that!
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
7 Replies 7
Jorge Armijo
Level 4
Level 4
If you issue "show mgcp end" and you're not getting a positive result, it means that for some reason the Gateway is not taking the MGCP dial-peers for the FXO ports, you can try by adding manually those dial-peers:
port 2/0
service mgcpapp
Then issue "no mgcp" and "mgcp" and reset the GW on CUCM.
Please give it a try and let us know!
Jorge Armijo
should the service mgcpapp command be run from inside the dial-peer config? because:..........
Voice-GW(config-dial-peer)#?
DIALPEER configuration commands:
  answer-address         The Call Destination Number
  application            The selected application
  authentication         SIP Digest Authentication Configuration
  call-block             Incoming Call Blocking
  capacity               capacity update timer config
  carrier-id             Configure Carrier ID
  clid                   Caller ID option
  corlist                set the Class of Restriction lists
  default                Set a command to its defaults
  description            Dialpeer specific description
  destination            Outbound dial-peer match config
  destination-pattern    A full E.164 telephone number prefix
  digit-strip            Use digit strip option for the POTS digits replacement
  direct-inward-dial     Use Called Number as final call destination
  dnis-map               The name of a configured dnis-map
  exit                   Exit from dial-peer configuration mode
  fax                    Configure fax
  forward-digits         Configure the destination digits forward of this dialpeer
  huntstop               Stop hunting on Dial-Peers
  incoming               Incoming called number
  information-type       Information type for dialpeer
  max-conn               Sets the maximum connections per peer, negation sets to
                         unlimited
  no                     Negate a command or set its defaults
  numbering-type         The calling/called party numbering type
  permission             set the call orig/term permission of this dialpeer
  port                   Voice port associated with this peer
  preference             Configure the preference order of this dialpeer
  prefix                 The pattern to be dialed before the dialed num
  register               Register the E.164 number of this dial peer with gatekeeper
  resource               Resource allocation policy
  session                The session [ target | protocol | transport ] for this peer
  shutdown               Change the Admin State of this peer to down (no->up)
  supplementary-service  Config supplementary service features
  supported-language     Language(s) supported by the peer
  tgrep                  TGREP config
  tone                   Generate tones
  translate-outgoing     Translation rule
  translation-profile    Translation profile
  trunk-group-label      Configure Trunk Group Label
  trunkgroup             trunk groups associated with this peer
  voice                  Configure GATEWAY dial-peer for voice services
  voice-class            Set Dial-peer voice class control parameters
could it be an ios version problem?
Yes, you should be able to see the command "service". Maybe you can try with a newer IOS, on the "T" train:
IP VOICE W/O CRYPTO
c1700-ipvoice-mz.124-15.T9.bin
I was lookign at the Feature Navigator and didn't find any specification on the FXO ports, so you may give it a try.
Jorge Armijo
Rafael Carvalho
If you are using the host name as it is configured on the IOS gateway, the name that you enter in Domain name field must match exactly.
For example, if the hostname is configured on the gateway to resolve to vg200-1 and the IP domain name is not configured, enter the hostname in this field (in this case, vg200-1).
If the hostname is configured on the gateway as vg200-1 and the IP domain name is configured on the gateway as cisco.com, enter vg200-1.cisco.com in Domain name field.
Elliot,
port 2/0
application mgcpapp
no mgcp
mgcp
Alex.
Alex, Jorge thanks very much for this it has worked. Is there any reasoning for this or is it just a bug?
