05-06-2014 11:55 AM - edited 03-16-2019 10:42 PM
So I've posted up another thread about one of my serial interfaces having an issue, and I wanted to swap out the router. But I'm unable to get the MGCP gateway to register. The status is UNKNOWN. I can see the IP address of the router under the list of gateways, but status states unknown. I've searched high and low online about what causes this, but I've seen many threads left to die with no resolution. Any ideas as to what causes the unknown status. I've configured everything the same as the old router, and made sure to change the name of the router accordingly. Any thoughts?
05-07-2014 01:44 PM
Sure Brian!! Thanks for jumping on to help!! Much appreciated!
sh isdn status
Global ISDN Switchtype = primary-4ess
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/2/0:23 interface
dsl 0, interface ISDN Switchtype = primary-4ess
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 0
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not apply
ISDN Serial0/2/1:23 interface
dsl 1, interface ISDN Switchtype = primary-4ess
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
Active dsl 1 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 1
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 2. Layer 3 output may not apply
ISDN Serial0/3/0:23 interface
dsl 2, interface ISDN Switchtype = primary-4ess
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 2 CCBs = 0
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 3. Layer 3 output may not apply
ISDN Serial0/3/1:23 interface
dsl 3, interface ISDN Switchtype = primary-4ess
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 3 CCBs = 0
Total Allocated ISDN CCBs = 0
sh run | sec controller
controller T1 0/2/0
framing esf
clock source internal
linecode b8zs
cablelength long 0db
pri-group timeslots 1-24 service mgcp
controller T1 0/2/1
framing esf
linecode b8zs
controller T1 0/3/0
framing esf
linecode b8zs
controller T1 0/3/1
framing esf
linecode b8zs
05-07-2014 01:51 PM
It looks like a possible RIS database issue since everything from the gateway side seems to show registered and backhaul channel is up.
Can you make calls successfully?
You may have to restart the RIS Data Collector service on your CUCM nodes to get the webpage to show the correct registration status.
Can you run "show risdb query gateway" from the 192.168.111.6 node?
05-07-2014 02:14 PM
No I get a fast busy. I don't believe I have a RIS Data Collector. Please keep in mind I'm running CCM 4.1 the old stuff :(
