04-25-2016 11:31 AM - edited 03-17-2019 06:42 AM
Hi Everyone,
I'm looking for a configuration that if the MGCP link with both Call Managers go down, to alert Telco that the link is down, so they don't send calls to that PRI and would know to roll over the lines to another PRI which terminates at another GW
We had an outage where MGCP lost connectivity to CUCM cluster. Telco is suppose to roll over to another PRI if calls are failing. Since Telco does not monitor our GW connectivity to CUCM, they don't get alerted and still send calls to our GW.
Telco is suppose to roll over to another PRI GW if calls are failing.
Just wondering if there is a command on the GW to alert them.
Sharri
Solved! Go to Solution.
04-27-2016 11:22 AM
Yes you understanding is correct above example was for if MGCP PRI goes down.
However If MGCP gateway gets unregistered somehow then also you can set up a custom alert for that using RTMT.
You need to go to performance - choose CUCM where MGCP is registered - Go to Call manager-registered MGCP gateway.
Once it is open then you can set a customize the alert.Alert will send an email if any MGCP devices gets unregistered.
04-25-2016 12:19 PM
This is one drawback of MGCP if it loses conenction to even primary or secondary , we loose the calls.IF both then we are doomed.
In my view you can set the RTMT alert for the MGCP PRI and it will send alert email for PRI events to tech team or telco whenver it is down or flapping.
Subject: [RTMT-ALERT-AdminCUCM] MgcpDChannelOutOfService
MGCP Channel is out-of-service
Channel-Out-Of-Service status in gateway device(s): S0/SU0/DS1-3@hostname
04-26-2016 09:12 AM
Thank you for the reply Deepak.
I will suggest that to the client. Just wanted to verify before letting them know.
04-26-2016 11:13 AM
Welcome ,please mark it as answered if no more queries.thank you
05-03-2016 09:58 AM
Thanks Deepak.
That's the information I was looking for
Sharri
04-27-2016 10:44 AM
Hi Deepak,
I'm a little bit confused, this alert will be sent if the PRI goes down but if MGCP connection to Call managers go down RTMT won't send the alert . right ?
04-27-2016 11:22 AM
