04-27-2016 12:05 PM - edited 03-17-2019 06:44 AM
Hi Team,
I have been configuring the informacast paging by following the step by step configuration guide. I chose to use a SIP trunk for this setup and when I am dialing the extension i kept getting a busy tone.
Can someone guide me on troubleshooting this issue?
04-27-2016 08:57 PM
Please verify the complete config on cucm and Informacast as per the following
http://www.cisco.com/c/en/us/support/docs/unified-communications/paging-server/117059-configure-informacast-00.html
If the issue still exists then you need to get detailed callmanager service traces for a failed call.
Manish
04-29-2016 06:15 PM
Thanks all for the responses.
I didnt get a chance to generate any logs or contact Informacast support. However this is my setup:
CUCM cluster- 192.168.0.3,192.168.0.4 (server network)
Paging server- 192.168.1.9( voice network, this is used for the IP phones)
1. A sip trunk was configured following the guide and busy tone was received when it was dialed. The dialcast entry was matched to route pattern. I am not sure what is required for the SIP trunk, but on the Informacast, I allowed sip access for both call managers ( i assume that was needed).
2. I also tried the CTI route point, and it got registered, however when I dial the number is just rings.
Would the paging server need to be on the same network as the call manager server?
I will provide feedback on Monday.
05-03-2016 08:36 AM
There is a paging log you can pull from InformaCast. Your running the virtual InformaCast server? SingleWire has a program that pulls logs off the server so you can see where the call is ending up. Here is a link to the tool. Run a test page then run this tool to pull the logs. There is video on how to use it in the link.
https://www.singlewire.com/tools/informacast-logtool-kit
04-28-2016 09:30 AM
Singlewire has awsome support. Just email them at support@singlewire.com. They have even helped me without a valid contract. Do you have dial-casts setup in singlewire for the number you are dialing?
