MGCP outbound calls are not getting connected
Hi All,
We have a MGCP gateway with a T1 trunk, Sometime the outbound calls will stop working and the incoming will work the same time. when we are dialing the digits we are getting fast busy tone. If we reset the MGCP gateway from CUCM, it will start working. Earlier we are getting this issue once in a month or quarter but now it's happening everyday. When we are checking for real time call logs in RTMT it's not showing any logs in RTMT or in CDR but I have enabled MGCP debug on gateway and Call manger SDL logs and found that we are getting 500 unknown end point error.
Also while I am checking the sh ip int brief, It only listing few T1 controller logical ports. Ports from 14 to 22 are not coming.
Can any one suggest any fix for the issue.
Serial0/1/0:0 unassigned YES unset down down
Serial0/1/0:1 unassigned YES unset down down
Serial0/1/0:2 unassigned YES unset down down
Serial0/1/0:3 unassigned YES unset down down
Serial0/1/0:4 unassigned YES unset down down
Serial0/1/0:5 unassigned YES unset down down
Serial0/1/0:6 unassigned YES unset down down
Serial0/1/0:7 unassigned YES unset down down
Serial0/1/0:8 unassigned YES unset down down
Serial0/1/0:9 unassigned YES unset down down
Serial0/1/0:10 unassigned YES unset down down
Serial0/1/0:11 unassigned YES unset down down
Serial0/1/0:12 unassigned YES unset down down
Serial0/1/0:13 unassigned YES unset down down
Serial0/1/0:23 unassigned YES NVRAM up up
MGCP config
#sh run | sec mgcp
pri-group timeslots 1-14,24 service mgcp
ccm-manager fallback-mgcp
ccm-manager mgcp
mgcp
mgcp call-agent <CCMIP> 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
You only have PRI time slots configured for 1-14, so how can you expect the ports to show 14 and above?
Can you share the output of show controller t1? I need to see if there are any errors.
Response Signature
Thanks Nithin for clarifying about time slot,
FYI; As of now I have reset the gateway and calls are working, but from my last 1 week experience on this issue, it will go down in few hours.
Update : Now again outbound calls are not working. But incoming is working.
Please find the output for
#sh controller t1 0/1/0
T1 0/1/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20060707, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (87 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
0 Line Code Violations, 11 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 1 Degraded Mins
2 Errored Secs, 2 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 2:
0 Line Code Violations, 9 Path Code Violations
1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 3:
0 Line Code Violations, 1 Path Code Violations
1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 4:
3 Errored Secs, 3 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 5:
0 Line Code Violations, 4 Path Code Violations
2 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 6:
Data in Interval 7:
0 Line Code Violations, 12 Path Code Violations
4 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 8:
0 Line Code Violations, 10 Path Code Violations
3 Errored Secs, 2 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 9:
0 Line Code Violations, 3 Path Code Violations
Data in Interval 10:
0 Line Code Violations, 8 Path Code Violations
2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 37 Unavail Secs
Data in Interval 11:
Data in Interval 12:
0 Line Code Violations, 14 Path Code Violations
3 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 13:
0 Line Code Violations, 19 Path Code Violations
3 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 36 Unavail Secs
Data in Interval 14:
Data in Interval 15:
Data in Interval 16:
Data in Interval 17:
0 Line Code Violations, 17 Path Code Violations
Data in Interval 18:
0 Line Code Violations, 24 Path Code Violations
1 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 1 Degraded Mins
4 Errored Secs, 2 Bursty Err Secs, 0 Severely Err Secs, 32 Unavail Secs
Data in Interval 19:
Data in Interval 20:
Data in Interval 21:
Data in Interval 22:
0 Line Code Violations, 6 Path Code Violations
Data in Interval 23:
0 Line Code Violations, 5 Path Code Violations
Data in Interval 24:
0 Line Code Violations, 16 Path Code Violations
3 Errored Secs, 3 Bursty Err Secs, 0 Severely Err Secs, 26 Unavail Secs
Data in Interval 25:
Data in Interval 26:
Data in Interval 27:
Data in Interval 28:
0 Line Code Violations, 7 Path Code Violations
Data in Interval 29:
2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 30 Unavail Secs
Data in Interval 30:
3 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 33 Unavail Secs
Data in Interval 31:
2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 32:
0 Line Code Violations, 2 Path Code Violations
Data in Interval 33:
Data in Interval 34:
Data in Interval 35:
Data in Interval 36:
Data in Interval 37:
Data in Interval 38:
0 Line Code Violations, 13 Path Code Violations
Data in Interval 39:
Data in Interval 40:
0 Line Code Violations, 15 Path Code Violations
4 Errored Secs, 2 Bursty Err Secs, 0 Severely Err Secs, 25 Unavail Secs
Data in Interval 41:
Data in Interval 42:
27 Line Code Violations, 18 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 3 Line Err Secs, 1 Degraded Mins
6 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 90 Unavail Secs
Data in Interval 43:
Data in Interval 44:
Data in Interval 45:
Data in Interval 46:
1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 33 Unavail Secs
Data in Interval 47:
3 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 34 Unavail Secs
Data in Interval 48:
Data in Interval 49:
Data in Interval 50:
Data in Interval 51:
Data in Interval 52:
Data in Interval 53:
Data in Interval 54:
Data in Interval 55:
Data in Interval 56:
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 2 Degraded Mins
Data in Interval 57:
Data in Interval 58:
Data in Interval 59:
2 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 31 Unavail Secs
Data in Interval 60:
1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 30 Unavail Secs
Data in Interval 61:
Data in Interval 62:
Data in Interval 63:
Data in Interval 64:
3 Errored Secs, 2 Bursty Err Secs, 0 Severely Err Secs, 26 Unavail Secs
Data in Interval 65:
Data in Interval 66:
0 Line Code Violations, 315 Path Code Violations
2 Errored Secs, 2 Bursty Err Secs, 0 Severely Err Secs, 30 Unavail Secs
Data in Interval 67:
Data in Interval 68:
Data in Interval 69:
Data in Interval 70:
1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 18 Unavail Secs
Data in Interval 71:
0 Line Code Violations, 21 Path Code Violations
3 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 14 Unavail Secs
Data in Interval 72:
Data in Interval 73:
Data in Interval 74:
Data in Interval 75:
Data in Interval 76:
Data in Interval 77:
0 Line Code Violations, 22 Path Code Violations
3 Errored Secs, 3 Bursty Err Secs, 0 Severely Err Secs, 30 Unavail Secs
Data in Interval 78:
3 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 31 Unavail Secs
Data in Interval 79:
Data in Interval 80:
0 Line Code Violations, 18 Path Code Violations
Data in Interval 81:
Data in Interval 82:
Data in Interval 83:
3 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 35 Unavail Secs
Data in Interval 84:
3 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 32 Unavail Secs
Data in Interval 85:
Data in Interval 86:
Data in Interval 87:
Data in Interval 88:
Data in Interval 89:
Data in Interval 90:
Data in Interval 91:
3 Errored Secs, 2 Bursty Err Secs, 0 Severely Err Secs, 86 Unavail Secs
Data in Interval 92:
Data in Interval 93:
Data in Interval 94:
Data in Interval 95:
Data in Interval 96:
Total Data (last 24 hours)
27 Line Code Violations, 1227 Path Code Violations,
3 Slip Secs, 0 Fr Loss Secs, 3 Line Err Secs, 94 Degraded Mins,
202 Errored Secs, 115 Bursty Err Secs, 0 Severely Err Secs, 739 Unavail Secs
I can see errors on the T1 controller, which could be due to ISP issues or clocking configurations.
If such errors exist, I’ve seen similar behavior with other customers. I would recommend ensuring the controller is error-free.
If you don’t mind, could you share your configurations, hiding any confidential data
Response Signature
Hi Nithin,
Please find the attached Runn config.
