05-17-2013 05:28 AM - edited 03-16-2019 05:22 PM
MGCP Gateway is not registering.Pls help me guys.
05-17-2013 05:31 AM
Hi Kiran,
You need to provide voice Gateway config along with CUCM snapshot[Deivice -gateway]
Also, provide output of commands show ccm-mananger/show version /show diag from Router.
regds,
aman
05-17-2013 05:53 AM
What is your CUCM server version..?
05-17-2013 12:21 PM
Unfortunately in this forum no body can help on question like this, basic deployment scenario, traces debugs from gw what do you see show ccm manager command on go, whether cecum gw config is fine , whether the gw type is selected correctly along with correct slot for the pri cas qsig link lots of variables so the more info you provide better your chances of getting an answer
