Active Directory Sync Issue
clark white
Level 2
Level 2
Dears,
I am facing problem in sync CM with Microsoft AD, after configuring the LDAP directory it syn for the first time and get all the users and information in CM  after some time when i try to change telephone numbers in the AD for the users and tried to resync it doesnt reflects in CCM, it show me the same old records which it took at first syn.
Microsoft AD is windows 2008.
Any hints will be appreciated.
6 Replies 6
Hi Clark,
Are you sure you're saving the telephone number update in AD?
I have notice sometime change in AD are not reflected until you rry efresh the Organization Unit (OU) folder.
Try it and let me know.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
Dear Leo,
Thanks for your reply,
I did according to your instruction but no results
When i restart the Call manager the changes are reflecting, but again i tried to test for 1 more user by changing the telephone number and performed full sync, the new user telephone number is not synchronized.
This means everytime i do changes in AD i have to restart my Call manager for full sync and this is not possible. Also i tried to restart the DIR SYNC service but no results.
Any help
Dears,
Anybody can give me more hints where things are going wrong.
When you run the Full Sync in CUCM manually it doesn't work but if you restart CUCM it syncs? Have you verified that the Full Sync is ran successfully? Can you pull some LDAP logs from the time you performed the Full Sync?
Yosh
HTH Regards, Yosh
dojoy
When you create an LDAP Link on the CUCM you would find resync option.
"Perform a Re-sync Every"
By default it would be around 7 Days. You can try changing that to 1 hour.
Let us know if it worked out.
Hello Yash,
After restating the CUCM server when i perform a  full syn it is synchronizing all the info, After sync if i create a new user in the AD, then if i perform sync the new user doenst comes,
how to verify that??
  from where ? from CUCM or AD server ???
