Migrate pplication from Cisco Jabber to Webex.
liaz.zini
I want to migrate an application from Cisco Jabber to Webex. What settings are required to ensure Webex connects successfully to CUCM?
6 Replies 6
What do you specifically mean by “migrate an application from Cisco Jabber to Webex”? Can you please elaborate?
Response Signature
I want to use application Webex instead Cisco Jabber with CUCM
The Webex application uses the same service discovery as Jabber and uses the same configuration in CM, so there is nothing you’d need to do. Simply use the Webex application instead of Jabber.
Response Signature
I am using the same computer and the same cucm. Jabber connect, but Webex shows an error message that it cannot connect the phone services
Check that you have the needed SRV records created, _cisco-uds._tcp.<your domain> for internal connection and _collab-edge._tls.<your domain> for connections coming in via MRA Expressway.
Response Signature
