Migration to CUBE and SIP
garethpeart
Level 3
Level 3
Hi all,
I will be migrating from MGCP PRI over to SIP in the coming month and was trying to find out if I can use my 3945 to do both the CUBE and the PRI gateway functions at the same time while I'm doing the migration. I can always revert to an old 2811 if needed, but was wondering if it was possible.
CUCM version is 8.6 and router IOS is 15.0(1r)M16,
Chris Deren
Yes.  Make sure you have proper CUBE licenses though.
Chris Deren
I will have the license before I start. Thanks muchly for the answer... there may be more questions coming!
