03-07-2017 06:26 AM - edited 03-17-2019 09:44 AM
Hi Everyone.
How are you?
I am trying to build a lab for the CCIE, and I am considering to buy a 2901 ISR Gen 2 router to configuring Video Conference.
I have seen out there, there are PVDM3-16 selling in eBay, I wanted to know the minimum amount of PVDM I need to create a vied-conference 3 participants using the an standard Video codec.
I plan to use the 2901 Router to be my HQ router and it will have the following.
* Conference Resources.
* Frame Relay HWIC
* T1 PRI VWIC
What do you think guys, can you help me?
03-07-2017 08:53 AM
Using PVDM3 for video conferencing has been deferred for quite some time now, neither the IOS nor new CUCM releases have the option now.
And you required a PVDM3-128 for that.
03-07-2017 12:06 PM
Just adding to Jamie's point (I guess he is encouraging us to use 4k routers), with a 3 Party H264-VGA on G711 VC should be done on a PVDM3-64 with a full T1
However rather than going for a 1xPVDM3-64 I would go for 2, and in case you need you can use both, you are good.
Test in the lab, and if you can get by with just 1xPVDM3-64, then you can return the unused PVDM3
(Ebay usually has return policy)
Plz rate all helpful posts.
03-07-2017 12:08 PM
Not really, you cannot do video conferencing on ISR 4K either, you need vTP, MCU or CMS.
03-08-2017 11:31 PM
It's kind of a tricky one given that it is still currently in the CCIE, but is also a feature that has been removed like Jaime mentioned.
