Mobile SIP Client not working with UC540 while Desktop SIP client working Fine
sanjay.khurana
I have Cisco UC540 Voice Router. I have configured SIP services into that box to use 3rd party (3cx Softphone) SIP software on Phone / Desktop,
On Desktop Side my 3rd party softphone is working fine no issue while I am using same client on my andriod mobile I am getting error not
SIP/2.0 401 Unauthorized
I have captured desktop & mobile SIP registration logs from UC box.
Please help me to understand where I am doing mistake
mobile softphone logs file : mobile_logs.txt
desktop softphone logs file : desktop_logs.txt
6 Replies 6
Hi Sanjay,
Try to remove authentication command under sip-ua menu.
Please rate all useful posts
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice, CCNP Voice Certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
Hi ,
I am not able to find authentication  command under sip-ua menu.
I have attached sh runn of voice router can you please point the same in sh runn.
Try this:
voice register global
no authenticate register
After remove this command , I am still not able to connect here is latest logs which I captured after removed authencation.
I think the problem is the SIP Client installed on the cellphone. Try installing another version.
I have changed SIP client in mobile still have same problem
following is updated logs
UC540_Mumbai#
003664: Mar 22 09:16:40.315: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
003665: Mar 22 09:16:40.755: %SYS-5-CONFIG_I: Configured from console by gadmin on vty0 (14.140.113.82)
003666: Mar 22 09:16:59.700: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.76.10:5060;transport=tcp;lr SIP/2.0
Via: SIP/2.0/TCP 192.168.2.100:40995;rport;branch=z9hG4bKPjGkErKW3PjHTS-Ga3KtV8PDStesRm33xP
Max-Forwards: 70
From: "2099" <2099>;tag=Y32-rHeOZBOFcLTJ7OK1foXK-z6K7ynj
To: "2099" <2099>
Call-ID: JAZOSjL.xuGBlgI6yeQJtqOqyjCEOKQj
CSeq: 62272 REGISTER
User-Agent: CSipSimple_t03g-16/r1916
Contact: "2099" <2099>
Expires: 900
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Content-Length:  0
003667: Mar 22 09:16:59.700: //817/15C2983187DE/SIP/Event/sact_idle_new_message_register:
ccsip_api_register_ind return value : SIP_SUCCESS
003668: Mar 22 09:16:59.700: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
003669: Mar 22 09:16:59.704: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: "2099" <2099>
Date: Fri, 22 Mar 2013 09:16:59 GMT
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
003670: Mar 22 09:16:59.704: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: "2099" <2099>;tag=68249C4-FFFFE15B
WWW-Authenticate: Digest realm="",nonce="14FF19A200A6A0FA",algorithm=MD5,qop="auth"
Content-Length: 0
003671: Mar 22 09:16:59.712: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.2.100:40995;rport;branch=z9hG4bKPjiH9qaEujhFWzNulXIkXTLf770xpHxwZ4
Max-Forwards: 70
To: "2099" <2099>
CSeq: 62273 REGISTER
Expires: 900
Authorization: Digest username="2099", nonce="14FF19A200A6A0FA", uri="sip:192.168.76.10:5060;transport=tcp;lr", response="c91bf2ac03f67830fd229506bb53e4b2", algorithm=MD5, cnonce="OnKG8ifPO5qp7Z1T-re18Fxpr5ORxjUq", qop=auth, nc=00000001
Content-Length:  0
003672: Mar 22 09:16:59.716: //818/15C5096987DF/SIP/Event/sact_idle_new_message_register:
003673: Mar 22 09:16:59.716: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
003674: Mar 22 09:16:59.720: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: "2099" <2099>
Content-Length: 0
003675: Mar 22 09:16:59.720: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: "2099" <2099>;tag=68249D4-25C8
WWW-Authenticate: Digest realm="",nonce="9ECD730500A6A0FB",algorithm=MD5,qop="auth"
Content-Length: 0
003676: Mar 22 09:16:59.728: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.2.100:40995;rport;branch=z9hG4bKPjy8ks.WTTMJNt5S5CeYjxDEXHxODxFdYU
Max-Forwards: 70
To: "2099" <2099>
CSeq: 62274 REGISTER
Expires: 900
Authorization: Digest username="2099", nonce="9ECD730500A6A0FB", uri="sip:192.168.76.10:5060;transport=tcp;lr", response="54d3ba2488bf9ca4fc06f93e4a83ecf0", algorithm=MD5, cnonce="OnKG8ifPO5qp7Z1T-re18Fxpr5ORxjUq", qop=auth, nc=00000001
Content-Length:  0
003677: Mar 22 09:16:59.732: //819/15C6DDE187E0/SIP/Event/sact_idle_new_message_register:
003678: Mar 22 09:16:59.732: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
003679: Mar 22 09:16:59.736: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: "2099" <2099>
Content-Length: 0
003680: Mar 22 09:16:59.736: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: "2099" <2099>;tag=68249E4-8A7
WWW-Authenticate: Digest realm="",nonce="6CF8D3C900A6A0FD",algorithm=MD5,qop="auth"
Content-Length: 0
003681: Mar 22 09:16:59.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.2.100:40995;rport;branch=z9hG4bKPjPTup9g8nXdRy2h00oZzjvIEEB6G8Nztc
Max-Forwards: 70
To: "2099" <2099>
CSeq: 62275 REGISTER
Expires: 900
Authorization: Digest username="2099", nonce="6CF8D3C900A6A0FD", uri="sip:192.168.76.10:5060;transport=tcp;lr", response="04ecc11dd17ca617e0719528d5fc2828", algorithm=MD5, cnonce="OnKG8ifPO5qp7Z1T-re18Fxpr5ORxjUq", qop=auth, nc=00000001
Content-Length:  0
003682: Mar 22 09:16:59.748: //820/15C9EB4287E1/SIP/Event/sact_idle_new_message_register:
003683: Mar 22 09:16:59.752: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
003684: Mar 22 09:16:59.752: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: "2099" <2099>
Content-Length: 0
003685: Mar 22 09:16:59.756: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: "2099" <2099>;tag=68249F4-17F6
WWW-Authenticate: Digest realm="",nonce="54CC8F8400A6A0FF",algorithm=MD5,qop="auth"
Content-Length: 0
