03-12-2013 01:42 AM - edited 03-16-2019 04:12 PM
Hi all,
I have a installation with a MGCP gateway and want to configure mobile voice access (MVA). I configured a h323 gateway to the IP address of the MGCP gateway and configured hairpinning for my MVA number.
*Mar 12 08:20:37.953: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xBEF1
Cause i = 0x809B - Destination out of order
My Configuration details:
voice service voip
application
service cucm http://10.131.14.30:8080/ccmivr/pages/IVRMainpage.vxml
dial-peer voice 19041 voip
service cucm
session target ipv4:10.131.14.30
incoming called-number 1911905
codec g711ulaw
dial-peer voice 19042 voip
description Mobile Voice Access
preference 1
destination-pattern 1911904
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
CUCM - Service Parameter:
Mobile Voice Access Number: 1911904
CUCM - Media Resources - Mobile Voice Access Directory Number: 1911904/Everyone
CUCM - Route Pattern: 1911905/Everyone pointing to RouteList of H323 gateway for MVA
Can anybody see my mistake? User should dial external number 98601905 (internal 1911905) to access MVA.
Best regards
Manfred
03-12-2013 01:48 AM
HI
Your config is not look correct
Pls check this similar discussion.It will solve all your questions
https://supportforums.cisco.com/message/3873342#3873342
chrysostomos
03-12-2013 02:27 AM
Hi chrysostomos
can you please tell me more detailed what is not correct in your opinion?
I looked at https://supportforums.cisco.com/message/3873342#3873342 and the only difference I have seen is that I use the IP address of CUCU PUB in the dial-peers and in the other case there has been a change to CUCM SUP IP address.
I made this change to my configuration - without any change.
Best regards
Manfred
03-12-2013 02:44 AM
Did you performed the below steps:Its just an example
Get the IP address of the MGCP PRI gw
- On CallManager, create a dummy H.323 gw with that obtained IP address
- Use MVA hairpinning to redirect the MVA call :
- If MVA number is 69541236, and only the last 4 digits is passed to CallManager from the MGCP gw, I would create a Route Pattern 1236 (in a partition accessible by the 'Incoming CSS' of the MGCP gw) and point it to the dummy H.323 gw created
- You can then create a voip dial peer for incoming called-number 1236, with the mva service in VG
dial-peer voice 5001 voip
description Inbound dialpeer from UCM for triggering MVA VXML
service mva
codec g711ulaw
no vad
- I would recommend configuring Mobile Voice Acces number to be a different than 1236, to prevent a call loop. It also has to be unique. Let's say 5678 is a unique number for you. You can put in partition 'None', so that everyone can access it.
- Create another voip dial peer for destination-pattern 5678, and back to CallManager
- voice service voip
allow connections h323 to h323
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fsmobmgr.html#wp1126351 walks you through the steps of configuring MVA with hairpinning.
03-12-2013 03:32 AM
Hi chrysostomos
in my opinion that is exact what I did.
The 1234 in the example corresponds to my 1911905
The 5678 in the example corresponds to my 1911904.
Sorry, but I do not see any difference between the admin guide, the other supportforum case and my config. Maybe I´m blind and do not see my own mistake or... don´t know what´s wrong.
Best regards
Manfred
03-12-2013 08:04 AM
The numbers in cucm are 7 digits?the incoming digits in mgcp gw config is 7?
Lets say that is 7 digits
The voip dial peers pointed to cucm are h323 dial peers ??
service cucm
session target ipv4:10.131.14.30 ---------this dial peer are for incoming calls from cucm ..You dont need the session target
codec g711ulaw
dial-peer voice 5002 voip
destination-pattern 1911904 ------mva number (this is the number that you configured as an mva numbner in cucm)
session target ipv4: Pub ip or try sub
dtmf-relay rtp-nte
codec g711ulaw
no vad
voice service voip
03-13-2013 01:59 AM
Hi Manfred
Any news regarding your issue?
chrysostomos
03-13-2013 08:01 AM
Hi chrysostomos,
sorry for the delayed answer.
First - there is nothing new in the behaviour of my MVA.
Second - My internal dialplan on CUCM is 7digit, 3digit sitecode and 4digit extension.
1905 is the Number which user should dial for MVA
1904 is the Number which is configured in CUCM for MVA (see above for a detailed description)
My Dialplan:
These are the dial-peers which are configured at the gateway at the moment. The session target in dial-peer voice 19041 could be deleted - but no change in the behaviour.
service cucm
codec g711ulaw
preference 1
codec g711ulaw
no vad
Best regards
Manfred
