cisco unified CME 7.1 (need help)
shendisundari
hi,
i will make voip with cme at cisco router 2811 with cme 7.1 and used sip phone spa 303..spa 303 is supported by cme 7.1?if anyone has a reference about configure voip used ip phone spa 303 with cme 7.1 please share to me,thanks
Chris Deren
No, these phones are not supported with CME, they are only supported with these systems:
Supports both Session Initiation Protocol (SIP) for
Cisco SPA9000 Voice System
, open source, and hosted telephony solutions and Smart Phone Control Protocol (SPCP) for
Cisco Unified Communications 500 Series for Small Business
http://www.cisco.com/cisco/web/solutions/small_business/products/voice_conferencing/SPA_500/index.html
HTH,
Chris
oh,thank you chris deren....
whether softphone like x-lite or eyebeam supported by cme 7.1?iam a newbie in voip,do you have reference configure voip with protokol sip used cisco unified cme?with end point x-lite or either ip phone because often I find a configuration voip in packet tracer but are in fact different commad from the current configuration of the hardware
bernhardczapp
Level 4
Level 4
Though you are able to run SPA3XX Phones with UC500-Series it should also be possible to use them with Communications Manager Express.
Have a look at the this guide for more information:
https://supportforums.cisco.com/docs/DOC-9465
(this ist not perfect but...)
Looks like these phone are integrated as SIP-Devices/Phones. This should work with any ccme
