Modify INVITE/SDP in Early Offer
drbabbers
Participant
Participant
All,
How do I modify the INVITE with CUCM on a SIP Trunk? Specifically I would like to remove h.264 from the Early Offer.
SIP Profile/Normalization Script? I have never done this before and am struggling.. So would appreciate any guidance or clear documentation.
D
You can go through this video tutorial:
https://supportforums.cisco.com/video/12151771/guide-sip-normalization-cucm-and-lua-scripting
Chakshu
6 Replies 6
Chakshu Piplani
Is the call going out to voice gateway?
Can you paste the current SIP INVITE and the desired SIP INVITE.
Call flow is from CUCM via SIP Trunk to a CUBE, but my question is can I modify the INVITE at the CUCM side? Or should this be done on the CUBE?
D
It will be easier on CUBE, create a sip profile and associate is with dial-peer
You can create a SIP profile like this:
voice class sip-profiles 100
request INVITE sdp-header Audio-Attribute modify "a=rtpmap:97 H264/90000" ""
Hope this helps.
Thank you for your help so far. Can you please advise though how this can be done in CUCM? Say that I had no CUBE and this was 2 CUCM clusters with a SIP Trunk, how would I do this in that example please?
D
Chakshu
Hi Chakshu,
Here is a snippet from the SDP INVITE:
I have highlighted what I would like to remove.
D
Recognize Your Peers
