08-30-2011 02:42 AM - edited 03-16-2019 06:44 AM
Hi all,
I try to use a new moh. So when I upload the file, I see in the list of "Music On Hold Audio File Management":
File name | Length | File Status |
SampleAudioSource | 5 min 38 sec | In Use |
SilenceAudioSource | 0 min 30 sec | Translation Complete |
mymoh | 0 min 0 sec | Opening /usr/local/thirdparty/jakarta-tomcat/temp/mymoh.audtmp |
So, when I try to add a new MOH Audio Source, I don't see in the list "MOH Audio Source File" the file that I added previously.
I try to restart Cisco Tomcat Service but without result.
Is someone have an idea?
08-30-2011 04:18 AM
Have you tried restarting the IPVMS?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
08-30-2011 04:25 AM
Hi Java,
and thanks for your help.
I restart IPVMS just after you post but it not results the problem.
An other idea?
08-30-2011 05:14 AM
would you mind to let me know the size of your .wav file?
08-30-2011 05:17 AM
of course. the size of the .wav file is 1,22 MB
08-30-2011 06:23 AM
Hi all,
I try to convert the original mp3 file with another wav converter, and it works now!
So, be careful if you use the software "Switch Sound File Converter" to turn you mp3 files into wav.
Thanks all for your help.
