MOH for third party sip phones
iptsupport
Level 4
Level 4
Hello ,
I using CUCM version 9.1.1.2000-5  .
Does this version support MOH for third party sip phones ?
Thank you
8 Replies 8
Vivek Batra
I think yes b/c I can listen to default MoH playing to 3CX phone while kept on hold...
I need to configure anything special ?
Hi iptsupport,
 the 3rd Party Phone must support the Cisco-proprietary feature signaling for MoH to work (check this link as a reference).
Hope this helps.
Hi Marcelo Almeida
Thank your for your quick replay .
I will try to follow the configuration in the link .
Do you have example to a client that support MOH  ?
Hi iptsupport,
 sorry I don't have an example of a third-party Phone that support MoH.
 I think (I'm guessing right now) that Polycom equipment has a better chance to support MoH, because the Cisco 7936 and 7937 are both Polycom/Cisco equipment.
Hope this helps.
I couldn't found better piece of information which list all cases how MoH is implemented for various terminals and hence thought of testing the same. My observations;
SCCP phone -> Hold -> SIP Phone -> MoH plays to SIP phone
SIP Phone -> Hold -> SCCP phone - > Doesn't play MoH
SIP Phone -> Hold -> SIP phone -> Doesn't play MoH
Please note that I have checked with both Xlite and 3CX, results are same.
I have verified in wireshark also,  call manager is not sending RTP packets to held party when call is hold by third party SIP phone.
Checked in CUCM 9.1
Vivek
Can you share with me the 3CX  configuration ? I was unable the register mine .
When useing  x lite 3.0 I didn't heard MOH .
