MOH issues with CME4 Multicast
GOLDEN4GOD
Does anyone have MOH live feed connected to E&M ports with Multicast. Users are hearing Tone on Hold instead of Music on Hold.
THe Debug ephone MOH shows "no music resources available, or No DN entry.
We have this standard configured for over 200 branches and only 100 sites are working.
Club330-2811#
No MOH entry for DN 1
:No MOH resources available for DN 81 chan 1 codec 11
voice-port 0/1/0
auto-cut-through
operation 4-wire
signal immediate
no vad
description MOH ......................... Music on Hold System (DMX)
multicast moh 239.10.16.8 port 2000 route 172.24.89.193
ephone-dn 79
number AA
description ***** Music On Hold *****
moh out-call 79
067
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
maximum sessions 4
associate application SCCP
dial-peer voice 79 pots
description MOH ......................... Music On Hold
destination-pattern 79
port 0/1/0
mchandak
Level 7
Level 7
You have not mentioned ip address and port for this command. So if you want to use it as Multicast, those commands are must. Check the command ref for MoH(e-phone) at http://www.cisco.com/en/US/customer/products/sw/voicesw/ps4625/products_command_reference_chapter09186a0080611349.html
Thanks for the reply, here is the ipaddress and port. It is configured standard across all 300 locations and half work
multicast moh 239.10.16.8 port 2000 route 172.24.16.129
aciscolook
I have a near identical problem. Was your issue resolved? if so how?
