MoH on CME - how to remove the Quotation
Nasir Aziz
hi all
do any one have idea , how to remove the Quotation from  moh "flash0:/music-on-hold.au".  actually I am practicing on router 2911 without voice card ,  and the router is working nice and I configured also the ip phones 7941, 7942, 6921 .  but I couldn't solve the issue of the MOH.
the ios on the router are c2900-universalk9-mz.SPA.152-4.M3.bin. I can arrange to get VIC2 4FOX , but could this solve the issue of moh.
Thanks in Advance
Nasir Aziz
23 Replies 23
Mohammed Khan
Where do you see this quote?
What exactly are you trying to solve?
telephony-service
 no auto-reg-ephone
 max-ephones 50
 max-dn 300
 ip source-address 192.168.200.254 port 2000
 system message Voice Test NAGRP
 load 7941 SCCP41.9-4-2SR2-2S
 load 7942 SCCP42.9-4-2SR2-2S
 load 6921 SCCP69xx.9-4-1-3SR2
 time-zone 31
 time-format 24
 date-format dd-mm-yy
 dialplan-pattern 1 24187.. extension-length 7 extension-pattern 11377..
 max-conferences 8 gain -6
 moh "flash0:/music-on-hold-1.au"
 multicast moh 239.1.1.1 port 16384 route 192.168.200.254
 transfer-system full-consult
 directory last-name-first
 create cnf-files version-stamp Jan 01 2002 00:00:00
You cannot remove quote, its picked by the system by default.
R1(config-telephony)#moh flash0:music-on-hold.au
R1(config-telephony)#^Z
R1#sh run | sec tele
telephony-service
 moh-file-buffer 5000
 max-ephones 10
 max-dn 50
 ip source-address Z.Z.Z.Z port 2000
 moh "flash0:music-on-hold.au"
 create cnf-files version-stamp 7960 Jun 01 2016 16:47:56
R1#
I see, but even moh not functioning , still hearing beep
1. Can you send me the output of show ephone moh
2. Try a test call and when you put the call on hold run the command "show ccm-manager music-on-hold" and send me the output.
3. Make sure ccm-manager music-on-hold is given in the global config as well & ip multicast routing is enabled on the router.
4. Can you copy the file from the TFTP or an SFTP into the flash again using the command:
copy tftp: flash:
Aseem
CME#sh ephone moh
Skinny Music On Hold Status - group 0
 Active MOH clients 0 (max 210), Media Clients 0, B-ACD Clients 0
 No MOH file loaded
CME#sh ccm-mana
CME#sh ccm-manager
% Call Manager Application is not enabled
CME#sh ccm-manager
Do the following:
1. Enable ccm-manager music-on-hold in global config
2. enable Ip multicast-routing
3. type in following under telephony-service
moh music-on-hold.au
4. enable the multicast moh under ephone using the command
ephone 1
multicast-moh
5. Specify the G711 codec explicitly under ephone
Aseem
thanks Aseem
but still not work , still show the ccm-manager not enable. I erase every thing but still
Hi Nasir,
Please log the file and collect the output of:
show ephone moh
show telephony-service
Show run
Show flash
Aseem
thanks for your reply , I install yesterday VIC2-4FXO Voice Interface Card  I found it in our store and trying to configure it also
Nasir Aziz
Hi Nasir,
As per the running configuration i dont see MOH configuration in place. Can you please apply the below configuration and test between ephone 1 and 2:
telephony-service
moh flash:music-on-hold.au
ephone 1
multicast-moh
no mtp
ephone 2
multicast-moh
no mtp
Disable mtp under 2 ephones to test with and apply codec G711ulaw .
Once you apply the configuration collect the output of show ephone-moh
Aseem
yes now working , but strange I done it may time I don't know why it not work?
any how thank you very much , also do you have idea regarding
VIC2-4FXO Voice Interface Card  , I want also to configure analogue phone on it.
Hi Nasir,
You are most welcome! Please rate the useful posts. Regarding FXO, the FXO cards are used to connect to analog lines and FXS cards are used for analog endpoints like modem/analog phone etc.
https://supportforums.cisco.com/discussion/9143796/what-difference-between-fxs-and-fxo-voice-cards
http://www.cisco.com/c/en/us/td/docs/ios/12_2/voice/configuration/guide/fvvfax_c/vvfport.html#wp1133494
Aseem
I refer to your links , so that mean the FXO will not  work on analogue phone. I need FXS .
thanks for your information
also Thanks for Mohammad for his support
