Monitoring ISDN channel usage over SNMP on ISR4321
Tom Ribbens
We recently installed ISR4321 voice gateways. They have 2 ISDN PRI E1 interfaces provided by the NIM-2MFT-T1/E1 - T1/E1 Serial Module.
We have those devices included in our PRTG monitoring system. Now I wanted to add sensors that show the channel usage of the ISDN lines. Googling for the SNMP string, I found this one: http://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.10.19.1.1.4#oidContent
Unfortunately, that does not work. As does many others I have tried that might have seemed relevant. I now believe the feature is completely changed in this ISR family compared to previous ISR families.
In case it's important, we're running isr4300-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin
Kind regards,
Tom
9 Replies 9
Georgios Fotiadis
What does
snmpwalk -v2c -c <community> <isr_ip> 1.3.6.1.4.1.9.10.19.1.1.9
return?
Georgios
Please rate if you find this helpful.
I don't have that snmpwalk utility on a network that can directly access the device, but when I use the Paessler snmp tool, I simply get nothing.
----------------------- New Test -----------------------
Paessler SNMP Tester 5.1.3
9/01/2018 13:21:48 (4 ms) : Device: 10.25.0.19
9/01/2018 13:21:48 (5 ms) : SNMP V2c
9/01/2018 13:21:48 (7 ms) : Walk 1.3.6.1.4.1.9.10.19.1.1.9
When I try something else, I do get information back:
9/01/2018 13:23:28 (6 ms) : Device: 10.25.0.19
9/01/2018 13:23:28 (10 ms) : SNMP V2c
9/01/2018 13:23:28 (13 ms) : Walk 1.3.6.1.2.1.1.3
9/01/2018 13:23:28 (23 ms) : 1.3.6.1.2.1.1.3.0 = "187295866"
I suppose the output you sent if when asking for a specific OID.
Can you have the whole tree (from root) returned to you? There, you should be able to see the required OIDs. Asking with root 1.3.6.1.4.1.9.10.19.1.1.9 should return you info regarding the PRI lines.
Georgios
The output should be that of a walk, so the whole tree:
9/01/2018 14:53:13 (6 ms) : Device: 10.25.0.19
9/01/2018 14:53:13 (10 ms) : SNMP V2c
9/01/2018 14:53:13 (13 ms) : Walk 1.3.6.1.4.1.9.10.19.1.1.9
9/01/2018 14:53:32 (8 ms) : Device: 10.25.0.19
9/01/2018 14:53:32 (11 ms) : SNMP V2c
9/01/2018 14:53:32 (15 ms) : Walk 1.3.6.1.2.1.1
9/01/2018 14:53:32 (26 ms) : 1.3.6.1.2.1.1.1.0 = "Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S6, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 24-Jul-17 20:26 by mcpre"
9/01/2018 14:53:32 (38 ms) : 1.3.6.1.2.1.1.2.0 = "1.3.6.1.4.1.9.1.2093"
9/01/2018 14:53:32 (50 ms) : 1.3.6.1.2.1.1.3.0 = "187836263"
9/01/2018 14:53:32 (61 ms) : 1.3.6.1.2.1.1.4.0 = ""
9/01/2018 14:53:32 (71 ms) : 1.3.6.1.2.1.1.5.0 = "tel-cube03.mechelen.intra"
9/01/2018 14:53:32 (83 ms) : 1.3.6.1.2.1.1.6.0 = ""
9/01/2018 14:53:32 (93 ms) : 1.3.6.1.2.1.1.7.0 = "78"
9/01/2018 14:53:32 (104 ms) : 1.3.6.1.2.1.1.8.0 = "0"
As you can see from this output, it does actually produce a tree of answers when querying it. 1.3.6.1.4.1.9.10.19.1.1.9 however produces no results.
9/01/2018 14:53:32 (71 ms) : 1.3.6.1.2.1.1.5.0 = "hostname redacted"
Can you attach (as file) the complete OID tree?
Georgios
Attached should be the output of this command:
 snmpwalk.exe -v 2c -c REDACTED 10.25.0.19 1 > full-snmp.txt
Indeed, the OID is not there. Alternatively, you can implement a script to login to the router and get the value that you want by executing "show voice call status" or sth.
Georgios
vincent.morton
Tom,
Did you ever find the OID for this? I've got the same problem trying to monitor a 4321
Vincent
