08-09-2017 08:27 AM - edited 03-18-2019 12:19 PM
Hello Friends,
I am facing strange behavior and want to understand root cause of this.
interasite call should be G.711 and intersite should be G.729.. configured appropriate region and applied on respected trunk and every thing is working perfectly.
CUCM: 9.1.1
1 ) HQ Site
have software conference bridge
and hardware transcoder in HQ router register to HQ CUCM.
2) BR1 Site
the problem is that when I am applying MRGL with hardware transcoder and software conference in HQ device pool then conference between HQ & BR is working perfectly when invoked by HQ Site.. and it is not working when I applied it on the HQ phone level MRGL..
Got confused. pls help me to understand it..
Thanks & Regards
Anil Singh
08-09-2017 05:53 PM
Typically the phone level MRGL has presedence over the device pool assigned mRGL. are both MRGL;s the same?
Please rate if helpful
08-09-2017 07:26 PM
Yes , that's why I am also surprised..
08-09-2017 08:19 PM
software conference bridge is working perfectly on Phone level also.. but transcoder is not invoked by phone level MRGL..
when I am using the same MRGL with transcoder , it is working perfectly at device pool level..
Not sure what is the issue..
08-09-2017 09:43 PM
when I removed the transcoder from the MRG group.. then the resource will be available to ALL devices, in what is know as "the default resource pool"
then , Phone Software conference (MRGL) is able to invoked transcoder and everthing is working perfectly.
But My requirement is to have limited no of the resources can invoked the transcoder..
thus trying to move it into different MRGL group (Xcodec) and trying to call it from phone MRGL(software conference resources) and then it is not working..
Pls help
08-09-2017 11:46 PM
Finally I manage to resolve the issue as per requirement.
In order to achieve this..
Software conference bridge/Media Resource must have the same device pool as of Transcoder then only , software conference (S/W MRGL) can invoked trascoder which is sitting on different Media resource group list at phone level.
