MS AD LDS
j.huizinga
Level 6
Level 6
I am trying to configure in the lab AD LDS (multi forest)
II follow the documentation but get stuck on "Import the Users from AD DC to AD LDS"
The main error is:
C:\Windows\ADAM>ADAMSync /install localhost:50000 c:\windows\ADAM\MS-AdamSyncConf-ADEX1.xml /log -
Establishing connection to target server localhost:50000.
Updating configuration file on c:\windows\ADAM\MS-AdamSyncConf-ADEX1.xml.
Reading Configuration File from c:\windows\ADAM\MS-AdamSyncConf-ADEX1.xml
Saving Configuration File on dc=home,dc=local
Attaching configuration file auxilliary class on dc=home,dc=local.
An ldap error occured while saving the configuration file: No Such Attribute
Done.
C:\Windows\ADAM>
Has any one seen this and maybe knows what is going wrong
JH
In the meantime I found a solution for my problem: the instructions for CUCM which I received, did not mention the required selection of MS-ADLDS-DisplaySpecifiers.LDF. Here is a screenshot of the instruction for a Windows 2012 environment (for a Windows 2003/2008 Cisco did select the MS-ADLDS-DisplaySpecifiers.LDF, but not for W2K12):
The instruction only mentions 4 LDF's, not 5.
For ADAM/LDS Bind Redirection Features you need at least the MS-ADLDS-DisplaySpecifiers.LDF (and MS-UserProxy.ldf)
When I added MS-ADLDS-DisplaySpecifiers.LDF with ldifde.exe this problem was solved.
9 Replies 9
Helweg
I've got the same problem:
Adamsync.exe v1.0 (6)
Updating configuration file on C:\Windows\ADAM\xxxx\MS-AdamSyncConf-xxxx.xml.
Reading Configuration File from C:\Windows\ADAM\xxxx\MS-AdamSyncConf-xxxx.xml
Saving Configuration File on dc=xxxx,dc=com
Attaching configuration file auxilliary class on dc=xxxx,dc=com.
Done.
Done.
Were you able to solve it?
Still not found the solution
Working some of my Microsoft colleagues to solve it
jan
Let me try this tomorrow in my LAB
Thanks for the update!
Jan
hi There,
Any luck ?
I am also stuck at exact same step. please help.
thank you
No, can import users, but authentication still an issue
Thanks for your response.
I am not able to sync users from AD's to ADLDS.
When doing the final step of sync it's giving me error.
From your response it seems you are able to sync users into cucm also.?
Would it be possible for you to share MS-userproxycisco.ldf
And the .XML files you have created for each forest..
I just want to compare.This will be great help.
Also if you can share some steps , guidance which is not listed in Cisco documentation ?
  • You need to select the four LDF's and MS-ADLDS-DisplaySpecifiers.LDF
  • Did you check on you local Active Directory Schema (your ADLDS server) if the Class userProxy contains all the attributes you defined (like sn, givenName, samAccountName etc.) in your XML and LDF files? If not, you need to create those attributes manually under the "optional" section of the userProxy's Attributes:
hi Helweg,
I was able to make it work , thanks for your response though. Much appreciated.
