02-13-2013 07:56 PM - edited 03-16-2019 03:42 PM
I have cucm 8.51 and cube.
I have iOS software mtp configured on the cube. Question is this. When i add codec pass-through under the dspfarm, cucm invokes correct mtp which is ios sw mtp but when I remove the command it always invokes the server mtp. Is pass-through command required command?
Per cisco TAC the command is not required but when I remove it cucm always invokes server mtp. When do you use codec pass-through? I am not using RSVP. If I leave the command it is not going to cause any issues?
Below is my config.
Dspfarm profile 20 mtp
Codec g729r8
Codec pass-through
Maximum session software 500
Associate application SCCP
Thanks for your help
Solved! Go to Solution.
02-28-2013 07:03 AM
Thanks all for the help on this issue.
Battling with CiscoTAC for many weeks, I finally figured out why I needed codec pass-thru on the CUBE.
This bug was first found on the 8.5(1)
02-14-2013 01:35 AM
Dear
Codec pass-through will make cisco UBE works as Transparent codec.To support the RSVP agent on a SCCP device, you must use the codec pass-through command. In the pass-through mode, the SCCP device processes the media stream by using a pure software MTP, regardless of the nature of the stream. This enables video and data streams to be processed in addition to audio. When the pass-through mode is set in a transcoding profile, no transcoding is done for the session; the transcoding device performs a pure software MTP function. The pass-through mode can be used for Secure RTP sessions.Other issue check the codec which is used between your call manager and the other it must be the same g72g.
Thank you
Please rate if this will elp
02-14-2013 05:01 AM
Vatter,
The most probable cause for this is that the device invoking the MTP region setting is not configured properly. With your configuration. You have configured MTP to use G729. What is the region setting between the device invoking MTP and the IOS MTP. Ideally it should be set to G729.
Check this and if you still have issues, send us the cucm trace files
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
02-14-2013 07:18 AM
Im having a similar problem. CUCM is allocating a MTP for SIP-Notify to RFC2833 conversion. It fails to allocate any MTPs on the IOS gateways (just set to codec g711ulaw) and only allocates CUCM software MTP.
I saw on the CUCM that the CUCM software MTP is doing pass-through. When I set the IOS hardware MTP to include "codec pass-through' it is then allocated.
sess_id conn_id call-id codec pkt-period dtmf_method type bridge-info(bid, cid) mmbridge-info(bid, cid) srtp_cryptosuite dscp
call_ref spid conn_id_tx
83894106 - 98948 N/A N/A rfc2833_report swmtpmsp All RTPSPI Callegs N/A N/A N/A
83894106 86704871 98947 pass_th 20 rfc2833_report rtpspi (16678,98948) N/A N/A 184
98328132 16777216 -
83894106 - 98948 N/A N/A rfc2833_pthru swmtpmsp All RTPSPI Callegs N/A N/A N/A
83894106 86704870 98946 pass_th 20 rfc2833_pthru rtpspi (16677,98948) N/A N/A 184
98328132 16777216 -
This is on CUCM
8.5.1.11900-21 and GW 15.1(4)M5. Both gateways and IOS MTP are in the same region, everything is g711, there is not any RSVP. The CUCM software MTP is actually in a different device pool and region (everything is set to g711 throughout though)
IOS MTP Device Caps (When codec-passthrough is added 258 is put in)
11:55:33.149 |MediaTerminationPointControl(44)::logCapabilitiesinTrace -- MTP/XCoder Device Caps = 4 257 259 261 |5,100,220,1.6069504^192.168.144.60^*
CUCM Software Device Caps
11:55:33.151 |MediaTerminationPointControl(8)::logCapabilitiesinTrace -- MTP/XCoder Device Caps = 25 4 2 257 259 258 |5,100,220,1.6069504^192.168.144.60^*
02-14-2013 08:21 AM
I am glad I am not the only one who is having this issue. What you just described makes sense.
We wanted to insert IOS mtp for our Type A phones.. ie) 7940 and 7921 WL phones because we have tons of 7940s at one of our remote site and we are just about to convert them to the SIP Trunk service and requirement is to use g729 instead of g711 codec. When I configure codec pass-though, everything works fine.
Here’s what I discovered while I was testing. When I changed the region where Server mtp is on to g729 from g711, it starts invoking IOS mtp however Conf and MOH is on that region and when you try to create a conference call, it is going to invoke xcode.
It looks like we are hitting a CUCM bug, in this case, can I leave codec pass-through under the dspfarm profile mtp? Is this going to cause any issues?
02-14-2013 08:46 AM
Vatter,
The first test you did proved what I already wrote earlier..This is a codec related issue. When you configure your MTp to use G729, you cant have the region set to G711 as you have discovered.
Why dont you create a seperate region for your conf and MOH. This is most definitely a configuration problem and not a bug.
02-14-2013 08:43 AM
Csdoziernc,
If you send the full CUCM trace logs, I can show to you that this is most likely a region cofiguration issues. If the IOS MTP is not allocated, its because the device invoking MTP cant talk the codec configured on the MTP.
Send us the full logs please and the details of the call.
02-14-2013 09:34 AM
Thanks for your reply aokanlawon. I am almost tempt to create a second region but i would like to understand this first.
The phone i am using to test and IOS sw MTP are on the same Region and it is using g729. Server MTP is on different Region which it uses G711. See below
Region:
-Server MTP
-SIP_Trunk
Media Resources:
-Server MTP: --- Region: Server MTP
-IOS sw MTP: --- Region: SIP_Trunk
Region setting for the phone i am using to test:
Phone region: g711
Server MTP: g711
SIP_Trunk: g729
CUBE setting:
dspfarm profile 20 mtp
codec g729r8
maximum sessions software 500
associate application SCCP
MRGL:
-IOS sw MTP
-Server MTP
Above is the setting i have on my system. When i make outbound calls, it always invokes Server MTP.. unless i change the Server MTP region to g729. What you are saying is this is normal? Per above configuration, isn't the phone supposed to invoke IOS sw MTP first?
02-14-2013 02:12 PM
Vatter,
Let me get your description correctly....can yo confirm if this is the correct region relationship
phone<------->iosmtp=g729
phone<--------------->cucmmtp=g711
phone<--------------->siptrunk=????
siptrunk<-------------->cucmmtp=????
Let me know what the codec used in the region where I put ??
To understand fully what happens on outbound calls, I need to see the config on your CUBE gateway. The dial-peers configured also plaay a role in the codec that is used, hence have an overall impact on the media negotiated for the call.
On your MRGL, do you have both cucmmtp and iosmtp in the same MRG asigned to this MRGL?
If you do then, the resources in the same MRG are assigned based on a round robin fashion, regardless of which is on top.
DO you mean it always invoke server MTP unless you change the region between your phone and iosmtp to g729.
Whatever codec you configure on your MTP is what the device invoking it will use. If your MTP is configured for G711, then the region between the phone and MTP has to be G711. If it is G729 then the region between the phone and the iosmtp has to be g729.
The reason why the server MTP is used is because CUCM MTP only supports G711. And because the region between your phone and the CUCM MTP is set to use G711..this is used.
02-14-2013 02:55 PM
phone<--------------->siptrunk=g729
siptrunk<-------------->cucmmtp=g711
On my MRGL, cucmmtp and iosmtp are not in the same mrg.
it always invokes cucmmtp unless i changed the phone region setting to cucmmtp to g729 than it uses iosmtp.
it doesn't matter which order I list in the MRGs in the MRGL, it always uses cucmtp unless I add codec pass-through in the CUBE or change codec to cucmmtp.
I also tried making outbound calls in our production phone that are using all g711 codec but it still does not invoke iosmtp. below is the region setting for my production phone.
phone<------->iosmtp=g711
phone<--------------->siptrunk=g711
This is too weird.... I created a TAC case but they are still haven't figure it out yet.
02-14-2013 03:41 PM
In your production network, it will not use iosmtp because the region settin is set to use G711 and your ios mtp is set to use G729. That is how it is designed to work.
The reason why it doesnt use cucm mtp when the region is set to G729 is also the same. CUCM MTP can only do G711, hence you must have G711 to the MTP.
So all that is working as expected.
Can you send me the CUCM traces, include the calling and called number. Can you also send the sh run of your cube
02-14-2013 03:53 PM
I can send traces and config tomorrow.
I forgot to mention. I am using separate cube for production and codec is set to g711.
02-28-2013 07:03 AM
02-28-2013 07:13 AM
Vatter, thanks for posting that bugID. It seems to explain the situation I saw as well.
CUCM Software MTPs allows codec pass-through by default (non configurable it appears), so if you have one in an MRGL, it gets used over an IOS MTP that doesn't have codec-passthrough when codecs are the same, etc.
