Using 2 devices in same extension number
jguandalini
Hello Guys, I have the scenario as below:
Extension number: 1001
Device1: Cisco 7942G
Device2: Cisco IP Communicator
The extension is configured in 2 devices.
Is possible I answer a call in Device1 and continue with this call in Device2, or vice-versa?
Today I need park the call to get the same call on the device2, but if I only take off-hook  the device2 doesn't work.
Thanks.
yahsiel2004
Level 7
Level 7
Jean,
I don't know if "Barge" would be ideal in this scenario since it turns the call into a conference but it would atleast allow another device that has the shared line to join the call. Below is a link with more information on barge if you want to consider it as an option.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fsbarge.html
Yosh
HTH Regards, Yosh
11 Replies 11
Harmit Singh
Hi Jean,
I havent tested this but as per documentation for call park:
Restrictions
•  For  shared line devices across nodes, the line will register to the node on  which the device registers first. For example, if a device from  subscriber2 registers first and the line is created in subscriber2 and  the publisher server, the line belongs to subscriber2. Each node must be  configured with the call park number.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fscallpk.html#wp1028114
HTH.
Harmit.
Hello Harmit, the call parking is working as well.
I would to know, without park the call, it's possible to move the call from device1 to device2, only getting the "phone hook" from the second device?
Thanks for your quick response.
Hi Jean,
Ah, I misunderstood in that case :-) Sounds like both the devices using the shared line are registered on the same node? Anyways, coming back to your question, provided the shared line is configured on SCCP Phones, you can try doing a "barge". However this wont be an option on SIP Phones.
HTH.
Harmit.
yahsiel2004
Level 7
Level 7
Jean,
Yosh
HTH Regards, Yosh
Yes, if it's a shared line and privacy is not enabled, you can put the call on hold on one device and resume in another one.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Anas Abueideh
Level 9
Level 9
if you put the call on hold it will be available on the other line.
Anas
kindly rate if it is helpful
Sent from Cisco Technical Support Android App
Thanks Guys, I think the Barge is the solution for my case.
But the key does not showing in the phone, even I configured the softkey template.
I need configure something in device before?
Where did you assign the cBarge softkey? Under connected, off hook or on hook etc
Yosh
HTH Regards, Yosh
Hello guys, I assign to remote. Now I can take the call.
See the example:
- Call from device1;
- Barge to device2;
- If I put device1 on hook, the call is finished.
It's normal?
What barge (Barge or cBarge) are you using? Did you change the Service Parameters on CUCM?
Located under: Serive Parameters>CallManager>Clusterwide Parameters (Feature - Join Across Lines And Single Button Barge Feature Set)
Yosh
HTH Regards, Yosh
I am using barge, and I can join in the conversation.
I will check these options and make the modifications.
THanks.
