MTP on 2821 being rejected by CUCM 9.1
coconino1969
Hello all
Using CUCM 9.1 and a Cisco 2821 (c2800nm-advipservicesk9-mz.124-24.T2 plus 64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card).
We currently have a SIP trunk to Telco with the "Media termination required" checked on the configuration to avoid dropping calls to certain numbers, this trunk is currently only used for 70 DIDs with 25 sessions, in the near future this is going to be used for 600 DIDs and 80 sessions, which is prompting me to create an MTP on the router itself.
Please see SCCP_config attachment.
I have been trying to set up an MTP and a transcoder on the router, the transcoder registers fine but the MTP keeps getting rejected by the CUCM
I see this message on the "debug sccp messages"  - sccp_process_swb_control_message: rcvd register rej from SWB CCM, reason: Error: DB Config
Any assistance would be greatly appreciated.
Example config:
dspfarm profile 3 mtp
codec g729ar8
codec g729r8
maximum sessions software 200
associate application SCCP
This will configure IOS software MTP for you. Yo can change the software session number to whateevr you l ike
You need to ensure that region between your sip trunk and the MTP is set to G729 if you are using G729 and G711 if you want to configure the software MTP to use G711
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Ayodeji Okanlawon
Your SCCP config doesnt have any MTP configured. You only have xcoder and CFB. You need to configure either IOS software MTP or hardware MTP depending on what you want.
Aokanlawon -
I need IOS software MTP, is there a document that you can point me to?
Thanks for the quick resp[onse.
Example config:
codec g729ar8
codec g729r8
     Thanks Aokanlawon, it's working now. Much appreciated.
