12-06-2007 08:24 AM - edited 03-15-2019 07:38 AM
Hi friend,
i've got a big plroblem, i haved configured multicast MoH with CCM/SrSt on remote site. On remote site when i call from PSTN I can hear MoH and when they put me in "waiting",on router SRST i see that Multicast MoH is working good . But the problem is when the customer call on-site, they can't hear MoH. what can be the problem?
Solved! Go to Solution.
12-11-2007 05:03 AM
Matteo, firstly I want clarify that I understand your topolgy, essentially you have a hub and spoke WAN with SRST at the remote branches which also provide MMoH?
If my understanding is correct, then the fact the 'show ccm-manager music' indicates that the CallManager is allocating the MMoH request, and therefore it is correctly configured for MMoH.
Ensure that your MMoH server/audio-source is associated with a device-pool where the region is configured to stream G711 to all other regions/remote branches. MMoH on IOS only support G711.
Two aspects which you initially try, firstly verify with 'show ephone summary' that the audio-file does not show invalid or in error.
If the file does show invalid then try removing and re-applying call-manager-fallback', this should correct the problem.
Secondly, add the gig0/0 interface to the mmoh command under call-manager-fallback:-
'multicast moh 239.1.1.1 port 16384 route 10.254.254.1 10.9.202.3'
Hope this helps.
Allan.
12-06-2007 08:36 AM
Make sure that you have the 'ccm-manager music' command configured on the voice gateway.
Allan.
12-06-2007 09:07 AM
the command issued were present in configuration , "ccm-manager music-on-old", but the problems is already present!
12-06-2007 01:01 PM
Please post the output of a 'show ccm-manager music' when you have a PSTN on-call on-hold, and also the configuration of the SRST gateway if possible.
Allan.
12-07-2007 06:12 AM
12-07-2007 04:02 PM
Matteo, thank you for providing the information I request, however I need to understand the exact issue.
What I need to know or clarify is what you mean when you say when the customer calls on-site, to you calling into remote-site from PSTN?
Allan.
12-10-2007 01:27 AM
For calls on-site i mean for example all calls in a location. I try to explain: i have two remote CCM, this remotes CCM provide he's services to 20 remote site that are built whit a router SRST in a MPLS network. When the customer make a call from 1 of this remote site and the call renain on the remote site, they can't hear the music-on-hold!
12-10-2007 02:02 AM
understand that the call remains on site but if the CCM is not resident on the same site, (i mean if the CCM is on the other site) still u need to enable multicast routing.....
because if i am not wrong the source of the MOH is the call manager and its not being able to route the MOH to the destination router....
forgive me if i am wrong...
12-07-2007 11:49 PM
You will need to enable some sort of multicast routing for the stream to go somewhere.
How is your voice gw connected to the local IP Phones?
Regards, Avner.
12-09-2007 02:48 AM
exactly......
multicast routing has to be enabled on the routers....
following is the syntax
in global configuration mode
ip multicas-routing
on the interfaces
ip pim dense-mode
ip join group
i dont exactly remember the syntax but this is just an indicative of what u need to do
12-11-2007 03:14 AM
yes, it's connected to local ip phones.
12-11-2007 05:03 AM
Hope this helps.
Allan.
01-02-2008 02:13 AM
