Multicast
banst8801
Hello guys,
I need help to configure multicast in the design showed below:
Please help!!!
PD: I was using the attached design, and it was working gr8!
Esteban
Jaime Valencia
Not sure this is the right area for you, this is the IP Telephony forum (multicast config is not IP Telephony), and FYI, you need to provide a lot more information than just "I need help".
java
if this helps, please rate
Well, perhaps you are right. But when you want to config MoH, or Paging you first have to config multicast on your network. Some info is missing, my mistake, sorry 4 that.
I did not find any documentation explaining MoH with the topology showed above. There are documents explaining multicast but only with the topology attached above (b4.png).
banst8801
Hi everyone,
My apologies for this, I was trying to deploy multicast with an incorrect IOS version.
