ANyone know a way to get 3 lines to appear on a 7841? The need is for a main DID and 2 other numbers to ring on the same phone in a Busy/No Answer situation.
Thanks in advance!
replies rated
I don't believe you can do that. But you might be able to use the Call PickUp feature to have the line on the 7841 be notified of an unanswered call on the other lines. Would that work?
Oops, overlooked. I think Mahoney is right. Dont think in 7800 we dont have to option to configure the Feature keys like in 8800. Sorry about that!
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
