Hello all, I am trying to create a new SIP trunk to my cubes individually to service a new need in the organization. Pass DTMF via a call consult transfer within UCCX. The goal is to pass the account number and PIN into a distant IVR. We have found that the only way to do that is to use MTP. I am unsure of the MTP resources needed to service the entire organization's call volume as it can be as high as 400 concurrent calls. My solution is to be able to create a new SIP trunk that only the route pattern will utilize that has MTP required checked. My real question is can I use a secondary IP on the interface of the CUBE to serve as the SVI that the call manager is pointing to for this trunk? Thanks in advance!
