05-02-2012 07:54 AM - edited 03-16-2019 10:56 AM
Hi All,
I need urgent help, we have multisite deployment with centralized call processing system. Lets say we have 2 sites Site A and Site B.
Site A = 8994999
Site B = 44102111
TeHO is already configured. When i dial mobile in site B area then i will dial as 900<country code><44102111> it goes to site B gateway and then that mobile number. But the display number will be site B . How can i change the calling number ?
05-02-2012 08:10 AM
At what level do you have configured the calling party number??
Also, a lot of telcos won't allow you to send something that does not belong to the DID range you own and will overwrite it with the main DID. Have you confirmed that's not the case and you're allowed to send anything as calling party??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-02-2012 09:30 AM
can u explain how to confirm the calling party number configuration???
How will i check if telco allwing us to do u have mentioned. Thanks
05-02-2012 08:33 PM
You can change calling number by configuring Calling Party Transformation CSS and assign it using " Use Device Pool Called Party Transformation CSS" in gateway configuration.
Configuration steps
1) Go to Calling Party Transformation Pattern Configuration :- Match your calling DN and enter the desired calling number value. This will change the calling number value.
Below is the link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b03trpat.pdf
You will have to check with your TELCO if they allow any calling number or they allow only the range which they have given for that ares. Most of the TELCO will not allow other region number to be displayed when calling from other region.
Ronak patel
Rate helpful posts by clicking stars below the answer.
05-02-2012 09:59 PM
Since im not using MGCP, even i have to use Calling party transformation CSS? Im using h323 prtocol.
05-03-2012 12:02 AM
You can use same feature for any kind of gateway.
Ronak Patel
05-03-2012 12:38 AM
can i do the same on gateway by using tranlation rules ?
