10-15-2012 04:08 AM - edited 03-16-2019 01:41 PM
Hi, Can anyone tell me if I remove the Music on Hold for one of our sites from the media resource group I have created for it - will the callers hear a beeping to let them know they are on hold or will there be complete silence? we are running call manager 7.1.5
Dominic
Solved! Go to Solution.
10-15-2012 04:25 AM
Assuming it doesn't end up in the default MRGL, yes, they'll get TOH
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-15-2012 04:25 AM
java
10-15-2012 04:38 AM
Dominic,
Just to clarify what Jamie said. TOH=beep. So yes they will hear beep.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
10-15-2012 07:34 AM
Thanks Guys for you help with this.
06-27-2024 05:21 AM
If you remove the Music on Hold (MoH) from the media resource group in Call Manager 7.1.5, callers placed on hold will likely experience complete silence unless you have an alternative hold notification configured. Typically, MoH is used to ensure callers know they are still connected during hold times. Without MoH, and without another form of notification, there will be no audible indication that they are on hold, which could lead to confusion or frustration.
If you want callers to hear a beeping sound instead of silence, you would need to configure an alternative hold treatment, such as a periodic beep or tone, if supported by your system.
