12-21-2012 05:08 AM - edited 03-16-2019 02:50 PM
I have cucm 8.5 integrated with unity onnetion 8.6.
For some reason, when i have voiemail, i dont see any MWI light on the handset. The Voicmail works very well but the MWI light does not come up.
Any help will be highly appreiated.
Regards.
Peter.
12-21-2012 05:38 AM
What type of integration do you have? SIP or SCCP?
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
12-21-2012 05:50 AM
SCCP
12-21-2012 05:54 AM
Does the CSS on your unity connection ports have access to the MWI Extension Partition?
12-21-2012 06:28 AM
Has the voicemail ever worked in the past? If so, try reseting the unity message waiting light indicator. You could also try to delete and add the MWI indicator back again in the unity mailbox.
Sometimes you need to kick cucm and connection to make it work.
HTH,
Han
