MWI not lighting on CME phones
pirinoe1920
Hello guys, we recently took over a phone system and it has the following problem.  When someone calls in and leaves a voicemail message the message waiting light does not appear or does not who the envelope.  Any ideas on what is missing from this configuration to enable the light
! Last configuration change at 17:45:23 Central Wed Feb 5 2014
! NVRAM config last updated at 17:47:13 Central Wed Feb 5 2014
version 15.1
hostname PBX_System
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 20
clock timezone Central -6 0
clock summer-time DST recurring
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.20.1 192.168.20.19
ip dhcp pool voip_dhcp
   network 192.168.20.0 255.255.255.0
   dns-server 75.75.75.75 75.75.76.76
   option 150 ip 192.168.20.1
   default-router 192.168.20.1
ip cef
no ipv6 cef
trunk group main
voice-card 0
license udi pid CISCO2801 sn FTX1111Z17K
interface FastEthernet0/0
ip address 192.168.20.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface Service-Engine0/1
ip unnumbered FastEthernet0/0
service-module ip address 192.168.20.5 255.255.255.0
service-module ip default-gateway 192.168.20.1
interface FastEthernet0/1
ip address X.X.X.X 255.255.255.224
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http path flash:
ip nat inside source list 1 interface FastEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip route 192.168.20.5 255.255.255.255 Service-Engine0/1
logging esm config
access-list 1 permit 192.168.20.0 0.0.0.255
tftp-server flash:S00105000400.sbn
tftp-server flash:P00308000800.loads
tftp-server flash:P00308000800.sb2
tftp-server flash:P00308000800.sbn
tftp-server flash:P00308000800.txt
tftp-server flash:OS79XX.TXT
tftp-server flash:cnu70.63-0-1-4.sbn
tftp-server flash:Jar70.63-0-1-4.sbn
tftp-server flash:jvm70.603ES1R4.sbn
tftp-server flash:term70.default.loads
control-plane
voice-port 0/0/0
trunk-group main 3
timeouts call-disconnect 2
timeouts ringing infinity
timeouts wait-release 5
connection plar 1051
description PSTN XXX-xXX-5353
caller-id enable
voice-port 0/0/1
trunk-group main 2
connection plar 1052
description PSTN XXX-XXX-5354
caller-id enable
voice-port 0/0/2
trunk-group main 1
connection plar 1053
description PSTN XXX-XXX-5355
caller-id enable
dial-peer voice 1 pots
trunkgroup main
destination-pattern 412.......
no digit-strip
dial-peer voice 200 voip
destination-pattern 2...
b2bua
session protocol sipv2
session target ipv4:192.168.20.5
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2 pots
trunkgroup main
destination-pattern 1..........
no digit-strip
gatekeeper
shutdown
telephony-service
max-ephones 30
max-dn 32
ip source-address 192.168.20.1 port 2000
system message My Business
cnf-file location flash:
load 7914 S00105000100
load 7960-7940 P00308000800
load 7970 TERM70.6-0-3SR1S
time-zone 8
voicemail 2000
max-conferences 8 gain -6
moh music-on-hold.au
multicast moh 239.2.2.2 port 2000
web admin system name xxxx password xxxxxxx
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Feb 05 2014 17:42:45
ephone-dn  1
number 1001
label Room 1
description Room 1
name Room 1
call-forward busy 2000
call-forward noan 2000 timeout 10
ephone-dn  2
number 1002
label Room 2
description Room 2
name Room 2
ephone-dn  3
number 1003
label Room 3
description Room 3
name Room 3
ephone-dn  4
number 1004
label Room 4
description Room 4
name Room 4
ephone-dn  5
number 1010
label Recep
description Recep
name Recep
ephone-dn  25
number 1051
label Main Line
description Main Line
name Main Line
ephone-dn  26
number 1052
label Line 2
description Line 2
name Line 2
ephone-dn  27
number 1053
label Line 3
description Line 3
name Line 3
ephone-dn  30
number 6000
label Paging
description Paging
name Paging
paging ip 239.1.1.10 port 2000
ephone-dn  31
number 8000....
mwi on
ephone-dn  32
number 8001....
mwi off
ephone  1
mac-address 0015.F9ED.3CDC
button  1:1
ephone  2
mac-address 001A.2FE7.7CFA
button  1:2
ephone  3
mac-address 001A.2FE7.79F6
button  1:3
ephone  4
mac-address 000F.3412.8D42
button  1:4
ephone  5
mac-address 0015.6389.B6FF
type 7960
button  1:5 3:25 4:26 5:27
line con 0
line aux 0
line 130
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120
line vty 0 4
login local
transport input telnet
scheduler allocate 20000 1000
ntp peer 192.168.20.1
ntp server 216.228.192.69
end
Manish Prasad
Level 5
Level 5
Add this..
dial-peer voice XXXX voip
description MWI
incoming called-number 800[0,1]....
codec g711ulaw
no vad
Check MWI status by "show ccn application"
Here is the useful link for MWI troubleshooting...
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-express/60081-unity-mwi-problems.html
Rate useful post.
Manish
Try below command and check it it works:-
IN CME:-
sip-ua
mwi server ipv4:192.168.20.5 unsolicited
In CUE:-
ccn subsytem sip
nwi sip unsolicited
Nishant Savalia
Regards, Nishant Savalia
MUDIT MATHUR
Hi Pirinoe,
There are three ways in which we can configure MWI.
Please find the configuration that needs to be done on CME and CUE for each method.
  1. Outcalling
  • CUCME:
dial-peer voice 100 voip
destination-pattern1000
session target ipv4:10.10.10.10
incoming called-number 399[89]….
codec g711ulaw
no vad
ephone-dn  1
number 3998…. no-reg primary
mwi off
ephone-dn  2
number 3999…. no-reg primary
mwi on
  • CUE:
ccn application ciscomwiapplication aa
parameter "strMWI_OFF_DN" "3998"
parameter "strMWI_ON_DN" "3999"
end application
2.SIP Subscribe Notify
CUCME:
sip-ua
mwi-server 10.10.10.10
ephone-dn 1
number 1001 no-reg
mwi sip
CUE:
ccn subsystem sip
gateway address "10.10.10.11"
mwi envelope-info
mwi sip outcall sub-notify
end subsystem
3.SIP Unsolicited Notify
CUCME:
sip-ua
mwi-server 10.10.10.10 unsolicited
CUE:
ccn subsystem sip
sip unsolicited
end subsystem
For more information, you can refer to following link as well.
https://supportforums.cisco.com/docs/DOC-1285
I would recommend using SIP unsolicited Notify.
Once the above configuration is done, go to the GUI of CUE and refresh all the mailboxes associated and make the test call.
Thanks & Regards,
Mudit Mathur
Thanks & Regards, Mudit Mathur
