my cius and 9951 can't register to cucm 8.6
farmercisco
    cius and 9951 auto register to my cucm8.6 ,from the CUCM's perspective, it says Status: Rejected.I know why.
My sccp phone is ok.
Brett Fritzsch
Zhou,
Check your Enterprise Parameter for auto-registration, by default its SCCP:
Keep in mind after changing this setting you need to restart CCM and TFTP most likely.
Hope this helps!
-Brett Fritzsch
Brett Fritzsch
Zhou,
Hope this helps!
-Brett Fritzsch
HI Breet,
it is ok.thank you.
integrotelecom
Hi, all!
I have the same problem. My sip phones is rejected by cucm 8.6. Changing Enterprise parameter SCCP to SIP does not help.
