12-06-2015 02:05 AM - edited 03-17-2019 05:07 AM
We are doing SIP trunk integration between Cisco call manager and NEC SV 8500. From NEC we are able to call Cisco user but one way speech ( Cisco user can hear NEC voice) but from Cisco we are not able to call NEC.
Can anyone help me on this issue
12-06-2015 07:46 AM
Is there a CUBE involved here, or is it direct integration from CUCM to NEC?
Is there a firewall or NATing taking place between the systems?
Is IP routing configured correctly to the NEC network?
Does DNA should the call as sucessful on CUCM side? Is configuration adequte on NEC side to accept the call?
12-06-2015 09:25 PM
Its direct integation from CUCM to NEC
Yes all communication is going thru firewall
12-07-2015 05:59 AM
Besides what Vivek suggests in the duplicate thread, make sure you have proper SIP ports (5060 UDP/TCP) opened bi-directionally as well as the UDP RTP range.
12-07-2015 03:23 PM
Hi Gohar,
We recommend you delete 1 of the 2 posts since it's the same question posted 2x.
Either delete this one or the other one: https://supportforums.cisco.com/discussion/12721816/nec-sv-8500-sip-connection-cisco#overlay-context=discussion/12576261/please-delete-multiplicates
12-06-2015 08:05 PM
Duplicate of;
- Vivek
12-12-2015 10:28 PM
Dear Batra
Could you please help me to solved this issue.
12-13-2015 08:27 AM
I am waiting for inputs for the question I asked before in duplicate thread;
Probably if you resolve second issue, first issue should also get resolved unless there is some network issue.
CUCM by default uses delayed offer which most of the PBX don't like. Either enable the SIP early offer under SIP Profile in CUCM OR share the SIP traces to know what's going on.
You should also check the other points asked by Chris.
- Vivek
12-13-2015 10:08 PM
12-13-2015 10:24 PM
Can you please recheck the logs, i am not able to unzip it.
- Vivek
12-13-2015 10:33 PM
12-14-2015 04:44 AM
The call doesn't exist in the trace. Calling number 51577 and called number 815566 doesnt exist.
Please collect the logs again and check the log that your call is present before sending it here to avoid wasting time..
You can refer to this document to understand how to collect cucm logs correctly..
https://supportforums.cisco.com/document/12724111/understanding-cucm-traces-end-end#Collecting_CUCM_logs
https://supportforums.cisco.com/document/12724111/understanding-cucm-traces-end-end#CUCM_Nodes_To_Download_Logs_From
12-14-2015 04:59 AM
Deji is right. Please follow his instructions and do the needful.
- Vivek
