Need Help with CallManager 8.0 upgrade to 8.5 on UCS B200
Thomas Park
I'm having problem with upgrading callManager 8.0 to 8.5 on UCS.
I downloaded the upgrade image merged the three files and made one iso.
I did md5 check on individual files but cound't find the md5 value for combined iso file, so I couldn't check md5 on the final iso file.
So I did try two upgrading method.  One through dvd mounted on local lap top and other through sftp on windows 2008.
Both upgrade process starts fine, but failed after 30~40 minutes.
I've attached the error output generated when the upgrade failed!
Is there any services I need to turn off? before installation?
(someone mentioned that I had to turn off extension mobility, so I tried it, but still the upgrade failed)
Is there upgrade manual for call manager in UCS?
Any suggestion?
Thank you~
8 Replies 8
Thomas Park
The following are the last line of error on failed upgrading (before vmware related output!)
Thanks again for taking your time looking at this~
02/14/2011 17:46:03 component_install|(CAPTURE) ugin.run  DEBUG:  Start DBMS|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:43:41 2011 dblstart-plugin.run  DEBUG:  do preflight|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:43:41 2011 dblstart-plugin.run  DEBUG:  <--|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:43:41 2011 cm-dbl-install.installdb  DEBUG:  IDS L2 Migration|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:43:41 2011 cm-dbl-install.installdb  DEBUG:  rm -f /tmp/*.txt /tmp/*.log /tmp/*.err /var/log/active/cm/trace/dbl/sdi/psqlx /tmp/*.bin /tmp/af* /tmp/shmem*|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:43:41 2011 cm-dbl-install.getPublisherFromPrefs  DEBUG:  -->|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:43:41 2011 cm-dbl-install.getPublisherFromPrefs  DEBUG:  Inside getPublisherFromPrefs...|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:43:41 2011 cm-dbl-install.getPublisherFromPrefs  DEBUG:  <--|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:43:41 2011 cm-dbl-install.installdb  DEBUG:  su -l informix -s /bin/sh -c 'source /usr/local/cm/db/dblenv.bash /usr/local/cm ; source /usr/local/cm/db/informix/local/ids.env L2 ; "/usr/local/cm/bin/installdb" -i -f L2 "/usr/local/cm" "/partB/usr/local/cm" 8.5.1.11900-21 8.0.2.40000-1 installdb_l2.log'|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:46:03 2011 cm-dbl-install.installdb  DEBUG:  <--|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:46:03 2011 cm-dbl-install.doL2_migrateDB  DEBUG:  <--|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:46:03 2011 cm-dbl-install.doL2Post  DEBUG:  <--|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:46:03 2011 cm-dbl-install.doActionL2Update  DEBUG:  <--|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:46:03 2011 cm-dbl-install  DEBUG:  cm-dbl-install [1]|<:DEBUG>
02/14/2011 17:46:03 component_install|(CAPTURE) Mon Feb 14 17:46:03 2011 cm-dbl-install  DEBUG:  <--|<:DEBUG>
02/14/2011 17:46:03 component_install|File:/opt/cisco/install/bin/component_install:673, Function: execute_cmd_list(), /usr/local/cm/script/cm-dbl-install L2 PostInstall 8.5.1.11900-21 8.0.2.40000-1 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt failed (1)|<:ERROR>
02/14/2011 17:46:03 appmanager.sh|Internal Error, File:/usr/local/bin/base_scripts/appmanager.sh:187, Function: upgrade(), failed to upgrade infrastructure_post components|<:CRITICAL>
02/14/2011 17:46:03 post_upgrade|File:/opt/cisco/install/bin/post_upgrade:146, Function: install_applications(), /usr/local/bin/base_scripts/appmanager.sh -upgrade -basepath /common/rpm-archive/8.5.1.11900-21 -logfile /common/log/install/install_log_2011-02-14.16.49.04.log -resultfile /common/log/install/upgrade-results.xml failed (1)|<:ERROR>
02/14/2011 17:46:03 upgrade_manager.sh|File:/common/download/8.5.1.11900-21/Cisco/base_scripts/upgrade_manager.sh:1174, Function: main(), Applications upgrade failed|<:ERROR>
02/14/2011 17:46:03 upgrade_manager.sh|Exiting with result 1|<:INFO>
02/14/2011 17:46:03 upgrade_manager.sh|IOWAIT monitor stopped|<:INFO>
Rob Huffman
Hi Thomas,
It looks to me that the wrong file is being used here;
02/14/2011 17:46:03 component_install|(CAPTURE) Attempt is made to upgrade Secure/Mixed Mode cluster to unrestricted mode, which is prohibited. You can upgrade non secured cluster to unrestricted mode.installdb Failure [-i] 1|<:DEBUG>
I think you are trying this file, which most builds won't use;
LOCAL_UCSInstall_UCOS_UNRST_8.5.1.11900-21.sgn.iso
it should be this one;
LOCAL_UCSInstall_UCOS_8.5.1.11900-21.sgn.iso
Cheers!
Rob
Thanks for reply, Rob.
Does this mean then I need to install restricted version of CallManager?
Because only two update iso that I can get from Cisco website is either restricted and unrestricted.
I had error when installing unrestricted, so restricted is the only option?
Also I thought, restricted is for export version only?
Rob Huffman
Hi Thomas,
Your current 8.0(x) version is "Restricted" and you cannot upgrade from Restricted
to un-Restricted or vise-versa it just won't work
The Restricted version is the one that has been around forever and is what 95%
of us run. The un-Restricted version only came out with the release of CUCM 7.1(5)
and it contains many changes to encryption that allows it to be shipped/installed in certain
countries around the world where it was previously not allowed.
Cheers!
Rob
Thank you so much for your help, Rob~
Rob Huffman
Hi Thomas,
You are most welcome my friend
Cheers!
Rob
Thomas Park
Is there any way to upgrade to unrestricted version?
restricted version of 8.0.2 to unrestricted version of 8.5?
I remember when I did the install of 8.0.2, there was no option of installing neither of restricted or unrestricted
So I'm suprised to find out that my installation of 8.0 is restricted version..
Rob Huffman
Hi Thomas,
If you really want to upgrade to the Unrestricted version
Upgrading to Unrestricted Cisco Unified Communications Manager 8.5(1)
Note The unrestricted version of Unified CM 8.5(1) is available in limited markets only.
Be aware that after you install or upgrade to an unrestricted release, you can never upgrade to a restricted version. You will not even be allowed to fresh install a restricted version on a system that contains an unrestricted version.
This section includes the following information:
Installing the Unrestricted COP File
To see if your current version of Cisco Unified Communications Manager is compatible with the unrestricted version of Cisco Unified Communications Manager 8.5(1), see http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
Before you upgrade from Compatible Versions of Cisco Unified Communications Manager 5.1(3x), 6.x or 7.x to unrestricted Cisco Unified Communications Manager 8.5(1), install the unrestricted COP file (ciscocm.allow_upgrades_to_unrestricted.cop.sgn) that you can find under:
Cisco Unified Communications Manager Version 8.5 -> Unified Communications Manager / CallManager / Cisco Unity Connection Utilities -> COP-Files
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_5_1/cucm-rel_notes-851.html#wp1840177
Cheers!
Rob
Please remember to rate helpful posts....
