Need Simple Dial Plan Help
I have a fully functioning dial plan but needed some help with a modification. I have attached the config.
We have a range of numbers (541-548-9400 - 9419) from our telco and I am using one of them for inbound calls which I translate directly to the Unity Express AutoAttendant.  That works great when I call the number.  All of our internal extensions have no correlation to our outside number because we have no DID's on our phones.  The number I am using for all inbound calls is 541-548-9400.
I have one particular user which does have a need for inbound calls to go directly to her phone.  I decided to use 541-548-9405 as her direct line.  I thought it would be easy so I gave her extension 215 and then created a translation rule that directs 9405 to 215 and then assigned a button on her phone as extension 215.
This does not seem to be working.
My main question is how can I have a single outside line (DID) assigned to just one single ephone so that when I call the 541-548-9405 it will ring just her phone?
version 15.1
service password-encryption
hostname voicerouter
boot-start-marker
boot-end-marker
card type t1 0 0
enable secret 4 t3Ic8qb5ewMDWvTa4L9l1WMKprop/NnpCj9WtdkqGGc
aaa new-model
aaa authentication login default local
aaa authorization exec login local
aaa authorization network login local
aaa session-id common
clock timezone PST -8 0
clock summer-time PST recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.8.1 192.168.8.19
ip dhcp pool owhvoip
 network 192.168.8.0 255.255.248.0
 default-router 192.168.8.1
 option 150 ip 192.168.8.1
 lease 30
isdn switch-type primary-ni
crypto pki server cme_root
 database level complete
 grant auto
 lifetime certificate 7305
 lifetime ca-certificate 7305
crypto pki trustpoint cme_root
 enrollment url http://192.168.8.1:80
 revocation-check none
 rsakeypair cme_root
crypto pki trustpoint cme_cert
crypto pki trustpoint TP-self-signed-2736782807
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2736782807
 rsakeypair TP-self-signed-2736782807
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 vpn-group 1
  vpn-gateway 1 https://66.220.104.251/SSLVPNphone
  vpn-trustpoint 1 trustpoint cme_cert leaf
 vpn-profile 1
  host-id-check disable
voice class codec 1
 codec preference 1 g711ulaw
voice class custom-cptone leavetone
 dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice class custom-cptone jointone
 dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice translation-rule 1
 rule 1 /9400/ /502/
voice translation-rule 2
 rule 1 /.*/ /5415489400/
voice translation-rule 3
 rule 3 /9405/ /215/
voice translation-rule 100
 rule 1 /^9/ // type any unknown plan any isdn
voice translation-profile Inbound_Calls_To_CUE
 translate called 1
voice translation-profile InternationalType
 translate called 100
voice translation-profile Local-CLID
 translate calling 2
voice translation-profile Sales_DID
 translate called 3
license udi pid CISCO2911/K9 sn FTX1641AHX3
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
username routeradmin password 7 091649040910450B41
username cmeadmin privilege 15 password 7 03104803040E375F5E4D5D51
username val password 7 074D63
username mark password 7 015144
username randy password 7 134755
username dylan password 7 004651
username elaine password 7 015144
username janis password 7 024446
username pam password 7 145550
username lisa password 7 125B47
username ruta password 7 074D63
username eli password 7 024446
username kimberly password 7 114B5B
username rebecca password 7 090E0C
username ronnda password 7 054944
username sarah password 7 100C4B
redundancy
controller T1 0/0/0
 cablelength long 0db
 pri-group timeslots 1-12,24
zone security trusted
zone security internet
zone-pair security trusted-to-internet source trusted destination internet
zone-pair security untrusted-to-trusted source internet destination trusted
interface Loopback0
 ip address 192.168.17.1 255.255.248.0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Internet
 ip address dhcp
 no ip redirects
 no ip proxy-arp
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.8.1 255.255.248.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:23
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
interface Integrated-Service-Engine1/0
 ip unnumbered Loopback0
 service-module ip address 192.168.17.2 255.255.248.0
 !Application: CUE Running on NME
 service-module ip default-gateway 192.168.17.1
 no keepalive
ip local pool SSLVPNPhone_pool 192.168.9.1 192.168.9.5
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/cme-gui-8.6.0
ip route 192.168.17.2 255.255.255.255 Integrated-Service-Engine1/0
tftp-server flash:apps31.9-3-1ES26.sbn
tftp-server flash:term31.default.loads
tftp-server flash:SCCP31.9-3-1SR4-1S.loads
tftp-server flash:jar31sccp.9-3-1ES26.sbn
tftp-server flash:dsp31.9-3-1ES26.sbn
tftp-server flash:cvm31sccp.9-3-1ES26.sbn
tftp-server flash:cnu31.9-3-1ES26.sbn
tftp-server flash:apps42.9-3-1ES26.sbn
tftp-server flash:cnu42.9-3-1ES26.sbn
tftp-server flash:cvm42sccp.9-3-1ES26.sbn
tftp-server flash:dsp42.9-3-1ES26.sbn
tftp-server flash:jar42sccp.9-3-1ES26.sbn
tftp-server flash:SCCP42.9-3-1SR4-1S.loads
tftp-server flash:cmterm_7936.3-2-21-0.bin
tftp-server flash:cmterm_7936.3-3-21-0.bin
control-plane
voice-port 0/0/0:23
voice-port 0/3/0
voice-port 0/3/1
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 192.168.8.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/1
 associate ccm 1 priority 1
 associate profile 1 register CME-CONF
dspfarm profile 1 conference
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 4
 associate application SCCP
dial-peer voice 500 voip
 destination-pattern 5..
 session protocol sipv2
 session target ipv4:192.168.17.2
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 10 pots
 description Incoming Calls To AA
 translation-profile incoming Inbound_Calls_To_CUE
 incoming called-number .
 port 0/0/0:23
dial-peer voice 20 pots
 description local 10 digit dialing
 translation-profile outgoing Local-CLID
 destination-pattern 9[2-9].........
 port 0/0/0:23
 forward-digits 10
dial-peer voice 30 pots
 description long distance dialing
 destination-pattern 91..........
 port 0/0/0:23
 forward-digits 11
dial-peer voice 40 pots
 description 911
 destination-pattern 911
 port 0/0/0:23
 forward-digits all
dial-peer voice 45 pots
 description 9911
 destination-pattern 9911
 port 0/0/0:23
 forward-digits 3
dial-peer voice 50 pots
 description international dialing
 translation-profile outgoing InternationalType
 destination-pattern 9T
 port 0/0/0:23
dial-peer voice 650 pots
 huntstop
 destination-pattern 650
 fax rate disable
 port 0/3/0
gatekeeper
 shutdown
telephony-service
 protocol mode ipv4
 sdspfarm units 5
 sdspfarm tag 1 CME-CONF
 conference hardware
 moh-file-buffer 90
 no auto-reg-ephone
 authentication credential cmeadmin tshbavsp$$4
 max-ephones 50
 max-dn 200
 ip source-address 192.168.8.1 port 2000
 service dnis dir-lookup
 timeouts transfer-recall 30
 system message Oregon's Wild Harvest
 url services http://192.168.17.2/voiceview/common/login.do
 url authentication http://192.168.8.1/CCMCIP/authenticate.asp
 cnf-file location flash:
 cnf-file perphone
 load 7931 SCCP31.9-3-1SR4-1S.loads
 load 7936 cmterm_7936.3-3-21-0.bin
 load 7942 SCCP42.9-3-1SR4-1S.loads
 time-zone 5
 time-format 24
 voicemail 500
 max-conferences 8 gain -6
 call-park system application
 call-forward pattern .T
 moh moh.wav
 web admin system name cmeadmin secret 5 $1$60ro$u.0r/cno/OD2JmtvPq4w9.
 dn-webedit
 transfer-digit-collect orig-call
 transfer-system full-consult
 transfer-pattern .T
 fac standard
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
 softkeys connected  Hold Park Confrn Trnsfer Endcall ConfList TrnsfVM
 button-layout 7931 2
ephone-template  2
 softkeys idle  Dnd Gpickup Pickup Mobility
 softkeys connected  Hold Park Confrn Mobility Trnsfer TrnsfVM
ephone-dn  1  dual-line
 number 200
 label Lisa
 name Lisa Ziomkowsky
 call-forward busy 500
 call-forward noan 500 timeout 10
ephone-dn  2  dual-line
 number 201
 label Dylan
 name Dylan Elmer
 call-forward noan 500 timeout 12
ephone-dn  3  dual-line
 number 202
 label Kimberly
 name Kimberly Krueger
ephone-dn  4  dual-line
 number 203
 label Randy
 name Randy Buresh
ephone-dn  5  dual-line
 number 204
 label Mark
 name Mark McBride
ephone-dn  6  dual-line
 number 205
 label Susan
 name Susan Sundin
ephone-dn  7  dual-line
 number 206
 label Rebecca
 name Rebecca Vaught
ephone-dn  8  dual-line
 number 207
 label Ronnda
 name Ronnda Daniels
ephone-dn  9  dual-line
 number 208
 label Matthew
 name Matthew Creswell
ephone-dn  10  dual-line
 number 209
 label Nate
 name Nate Couture
ephone-dn  11  dual-line
 number 210
 label Sarah
 name Sarah Smith
ephone-dn  12  dual-line
 number 211
 label Janis
 name Janis McFerren
ephone-dn  13  dual-line
 number 212
 label Val
 name Val McBride
ephone-dn  14  dual-line
 number 213
ephone-dn  15  dual-line
 number 214
 label Ruta
 name Ruta Wells
ephone-dn  16  dual-line
 number 215
ephone-dn  17  dual-line
 number 216
ephone-dn  18  dual-line
 number 217
ephone-dn  19  dual-line
 number 218
ephone-dn  20  dual-line
 number 219
ephone-dn  21  dual-line
 number 220
ephone-dn  22  dual-line
 number 221
ephone-dn  23  dual-line
 number 222
 label Pam
 name Pam Buresh
ephone-dn  24  dual-line
 number 223
ephone-dn  25  dual-line
 number 224
ephone-dn  26  dual-line
 number 225
 label Elaine
 name Elaine Mahan
ephone-dn  27  octo-line
 number 250
 label Shipping
 name Shipping
ephone-dn  28  dual-line
 number 251
 label Eli
 name Eli Nourse
ephone-dn  29  dual-line
 number 252
ephone-dn  30  dual-line
 number 253
ephone-dn  31  octo-line
 number 100
 label Customer Service
 name Customer Service
ephone-dn  32  octo-line
 number 101
 label Sales
 name Sales
 call-forward busy 214
 call-forward noan 214 timeout 12
ephone-dn  33  dual-line
 number 260
 label Conference Room
 name Conference Room
 call-forward busy 100
 call-forward noan 100 timeout 12
ephone-dn  100
 number 300
 park-slot timeout 20 limit 2 recall
 description Park Slot For All Company
ephone-dn  101
 number 301
 description Park Slot for All Company
ephone-dn  102
 number 302
ephone-dn  104
 number 8000...
 mwi on
ephone-dn  105
 number 8001...
 mwi off
ephone  1
 device-security-mode none
 mac-address 001F.CA34.88AE
 ephone-template 1
 max-calls-per-button 2
 type 7931
 button  1:2 2:31
ephone  2
 mac-address 001F.CA34.8A03
 ephone-template 1
 type 7931
 button  1:12
ephone  3
 mac-address 001F.CA34.898B
 ephone-template 1
 type 7931
ephone  4
 mac-address 001F.CA34.893F
 ephone-template 1
 type 7931
ephone  5
 mac-address 001F.CA34.8A71
 ephone-template 1
 username "susan"
 type 7931
 button  1:6
ephone  6
 mac-address 001F.CA34.8871
 ephone-template 1
 type 7931
 button  1:7 2:31
ephone  7
 mac-address 001F.CA34.8998
 ephone-template 1
 username "matthew"
 type 7931
 button  1:9
ephone  8
 mac-address 001F.CA36.8787
 ephone-template 1
 username "nate"
 type 7931
 button  1:10
ephone  9
 mac-address 001F.CA34.8805
 ephone-template 1
 type 7931
 button  1:5
ephone  10
 mac-address 001F.CA34.880C
 ephone-template 1
 type 7931
ephone  11
 mac-address 001F.CA34.8935
 ephone-template 1
 type 7931
 button  1:3
ephone  12
 mac-address 001F.CA34.8995
 ephone-template 1
 type 7931
 button  1:8 2:31
ephone  13
 mac-address 0021.5504.1796
 ephone-template 1
 type 7931
 button  1:4
ephone  14
 mac-address 001F.CA34.88F7
 ephone-template 1
 type 7931
 button  1:23
ephone  15
 mac-address 001F.CA34.8894
 ephone-template 1
 type 7931
 button  1:26
ephone  16
 mac-address 001F.CA34.8869
 ephone-template 1
 type 7931
 button  1:27 2:28
ephone  17
 mac-address 001F.CA34.885F
 ephone-template 1
 type 7931
 button  1:11
ephone  18
 mac-address 001F.CA34.893C
 ephone-template 1
 type 7931
 button  1:28
ephone  19
 mac-address 001F.CA34.8873
 ephone-template 1
 type 7931
 button  1:28
ephone  20
 mac-address A456.3040.B7DD
 type 7942
 vpn-group 1
 vpn-profile 1
 button  1:13
ephone  21
 mac-address 04C5.A4B0.5DA3
 type 7942
 vpn-group 1
 vpn-profile 1
 button  1:15 2:16 3:32
ephone  22
 mac-address A456.3040.B72E
 type 7942
 vpn-group 1
 vpn-profile 1
 button  1:1
ephone  23
 mac-address 00E0.75F3.D1D9
 type 7936
 button  1:33
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
line vty 0 4
 transport input all
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server 216.228.192.69
webvpn gateway sslvpn_gw
 ip address 66.220.104.251 port 443
 ssl encryption 3des-sha1 aes-sha1
 ssl trustpoint cme_cert
 inservice
webvpn context sslvpn_context
 ssl authenticate verify all
 policy group SSLVPNphone
   functions svc-enabled
   hide-url-bar
   svc address-pool "SSLVPNPhone_pool" netmask 255.255.248.0
   svc default-domain "bendbroadband.com"
 default-group-policy SSLVPNphone
 gateway sslvpn_gw domain SSLVPNphone
 authentication certificate
 ca trustpoint cme_root
 inservice
end
Hi @tditechsolutions,
In that case you have to do the following:
  • Delete the voice translation-rule 3 and the voice translation-profile Sales_DID
  • In the voice translation-rule 1 (which is attached to the translation-profile Inbound_Calls_To_CUE) add a second rule to match the DID of the number you want, in this case 9405
Should be like this:
no voice translation-rule 3
no voice translation-profile Sales_DID
 rule 2 /9405/ /215/
And the voice translation-rule 1 will have to rules:
 rule 1 /9400/ /502/
 rule 2 /9405/ /215/
When a call goes to the DID that terminates in 9405, it will be translated to 215 and redirected to the phone.
Don't forget to rate.
Rgrds,
Martin, IT Specialist
6 Replies 6
Martin Moran
Level 3
Level 3
I'm seeing that You created the translation-rule 3 and associated it to the translation-profile Sales_DID but you haven't applied that translation-profile to any dial-peer. I think that this is why that call is not getting translated.
Add (or use an existing) a dial-peer for the incoming calls and associate the translation-profile Sales_DID, and test again.
Rgrds,
Hi Martin. Thank you very much. I will try this. I thought I created a dial plan but I guess I missed that of course. I'll try it tonight.
Hi Martin,
I went to create this dial-peer but I already have incoming dial-peer's created so it occurred to me that I got confused where to enter an additional dial-peer for inbound calls - - dial-peer 10 already processes all inbound calls so if I enter another one, say dial-peer 11 then how will it know to catch the calls specifically for this case where I want it to go to a specific extension?
 rule 2 /9405/ /215/
 rule 1 /9400/ /502/
 rule 2 /9405/ /215/
Rgrds,
Thank you Martin!  I appreciate it.  I'll give this a try and I'm sure it will work just fine.
You're welcome my friend. Just let me know if you require further assistance.
Rgrds,
