Need to configure new 2900 router
Rakesh K
Hi Every one
I have got 2900 router and trying to enable E1 port. Not able to configure the same.
by going through the document found UCK9 type should be in   EvalRightToUse but on my router it is RightToUse.
is this cause of the issue.
Rakesh K
can anyone put some light on this
Rajan
Hi Rakesh,
That should not cause any issues. Can you provide below details to check.
- which module you are using
- What you have configured
- What is the error you are getting
Rajan
Pls rate all helpful posts
