11-15-2011 08:01 AM - edited 03-16-2019 08:04 AM
I got a Neopost postage meter attached to a VG202 and the VG202 is connected via h323 to CUCM 8.5.
The postage meter connects without any problems, but never charges $$$, as the connection tears down at about 60s.
Call flow is like this: Neopost----VG202---h323----CUCM8.5----h323----Cisco2921 PRI E1------ISDN Provider
See here the relevant configuration of the VG202 and the Cisco2921:
VG202:
BDVG202#sh run
voice service voip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
voice-card 0
interface FastEthernet0/0
ip address 192.168.243.4 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.243.4
voice-port 0/0
cptone CH
no ccm-manager fax protocol cisco
mgcp fax t38 ecm
dial-peer voice 150 voip
destination-pattern 00848783867
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.240.21
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 999000 pots
description Frankiermaschine
destination-pattern 299
incoming called-number 00848783867
fax rate disable
port 0/0
Cisco2921:
STHRO001#sh run
isdn switch-type primary-net5
voice-card 0
dspfarm
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
fax protocol pass-through g711alaw
h323
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /0/ /00/
voice translation-rule 2
rule 1 /^00/ /0/ type any national
voice translation-rule 3
rule 1 /^6/ /3265566/
rule 2 /^000/ // type national international
rule 3 /^0/ // type national national
voice translation-profile Outbound
translate calling 3
voice translation-profile SRST
translate called 2
voice translation-profile add_0
translate calling 1
controller E1 0/0/0
pri-group timeslots 1-31
interface GigabitEthernet0/0
description STH_Voice
ip address 192.168.240.2 255.255.255.0
duplex full
speed 100
h323-gateway voip bind srcaddr 192.168.240.2
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:15
cptone CH
mgcp profile default
dial-peer voice 1 pots
description Swisscom
translation-profile incoming add_0
translation-profile outgoing Outbound
destination-pattern 0.T
direct-inward-dial
port 0/0/0:15
forward-digits all
incoming called-number 0848783867
voice-class codec 1
voice-class h323 1
fax rate disable
Here is a debug isdn q931 of the Cisco2921:
Nov 15 15:37:50: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00B7
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x2181, '326556699'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '0848783867'
Plan:ISDN, Type:Unknown
Nov 15 15:37:50: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80B7
Nov 15 15:37:51: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x80B7
Nov 15 15:37:53: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x80B7
Progress Ind i = 0x8288 - In-band info or appropriate now available
Nov 15 15:37:54: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x80B7
Date/Time i = 0x0B0B0F0F25
Date (dd-mm-yr) = 11-11-15
Time (hr:mnt:sec) = 15:37:76
Connected Number i = 0x0183, '0848783867'
Nov 15 15:37:54: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x00B7
Nov 15 15:37:54: ISDN Se0/0/0:15 Q931: RX <- FACILITY pd = 8 callref = 0x80B7
Facility i = 0x91A11B02024D500201213012A10D810346522EA20681010A820101820100
Protocol Profile = Remote Operations Protocol
0xA11B02024D500201213012A10D810346522EA20681010A820101820100
Component = Invoke component
Invoke Id = 19792
Operation = AOCDCurrency
Currency = FR.
Currency amount = 10, Multiplier = 1/100
Type of charging : Subtotal
STHRO001#
STHRO001#
STHRO001#sh isdn act
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
Out 326556699 0848783867 66 0 0 0.10 FR.
STHRO001#
Nov 15 15:39:02: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x00B7
Cause i = 0x8090 - Normal call clearing
Nov 15 15:39:03: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x80B7
Facility i = 0x91A11A02024D550201233011300FA10D810346522EA20681010A820101
0xA11A02024D550201233011300FA10D810346522EA20681010A820101
Invoke Id = 19797
Operation = AOCECurrency
Currency = FR.
AOC-E Charging association Charge Identifier 0
Nov 15 15:39:03: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00B7
STHRO001#
Any idea what I'm missing?
Peter
03-13-2012 03:45 AM
I have resolved the issue with NeoPost machine connecting to the ATA-187 which is routed to PSTN thru h.323 gateway.
Please find the information as attached.
04-09-2013 09:53 AM
I'm stuck pretty much where you were at the time. Did the post by alvinchong really resolve the issue?
Were you successful at last?
Cheers
/David
