05-25-2011 01:01 PM - edited 03-16-2019 05:08 AM
Hi all
i wish know how to migrate data from Cluster UC CCM 7.0.2 to the new HW cluster with 8.0 . does DMA ?
thanks a lot.
Solved! Go to Solution.
05-25-2011 01:09 PM
DMA is a windows tool, for Windows to Linux upgrades.
The only way to migrate the info is to use BAT and adjust the info for the 8.0 to accept it.
EDIT: OR upgrade and the do a backup/restore, assuming the 8.X cluster has no data already in it
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
05-25-2011 01:09 PM
java
05-27-2011 06:50 AM
Hi HTH
Thanks for thw quick answer, i have other litle question: i have a Cisco Unity Express:
the packet of the unity Express license says that i dont need any license to active the unity exress, but i did the configuration on my router and CUE and it doesnt.
thanks.
