01-15-2020 09:18 AM
Hello There
So i have a AD 2016 and a Callmanager 11.5 runing togheter, and i want the Callmanager to make new RDP and RDs when the users are synced from the AD
Can the callmanager (or any othere product) do this?
Solved! Go to Solution.
01-15-2020 10:20 AM
CUCM has no way to do that, you would need to create a program that reads from LDAP and then uses AXL to create the necessary configuration in CUCM
01-15-2020 10:20 AM
01-15-2020 10:27 AM
Its 2020 and the answer is allways API :)
Thank you for the Replay and point in the right direction Jaime !
