01-14-2020 01:48 PM
Hello All,
Goal here is to send a call that is currently getting sent to CUCM where it then gets translated and routed accordingly, to have that number translated to another number before sending it along to the next Gateway instead.
The SIP Cube has a main inbound dial-peer that basically is a catch all to except the incoming call.
Currently on the SIP Cube/GW I created a translation-rule and profile:
! voice translation-rule 206 rule 1 /5551234567/ /2490/ ! ! voice translation-profile MAIN-FAX-INBOUND translate called 206 !
So I believe I now need an outbound dial-peer to direct the call to the next gateway in our network, where the fax machine is attached. And I was curious how the translation works. Does the translation rule/profile translate that number to 2490, and then send "2490" to the next Gateway? The next Gateway is expecting the number 2490.
Something like this?
! dial-peer voice 2608 voip description Fax Machine - 555-123-4567 translation-profile outgoing 800-FAX-INBOUND destination-pattern 5551234567 session protocol sipv2 session target ipv4: <fax-gw-ipaddr> dtmf-relay sip-kpml rtp-nte codec g711ulaw fax-relay ecm disable fax-relay sg3-to-g3 fax rate 14400 no vad !
Wasn't sure if I was supposed to use incoming or outgoing for the translation-profile line in the dial-peer. Is it technically outgoing since its an outbound dial-peer to our next Gateway?
Any help would be greatly appreciated.
Matt
Solved! Go to Solution.
01-15-2020 10:51 AM
Thanks Vaijanath.
I ended up doing it slightly differently. It was a little bit more configuration. But, the result is the same. On the CUBE I configured a dial-peer to take the full fax telephone number, and just send that full number to the 2nd Gateway (*a 2821). On the 2821 I have a voip dial-peer with incoming called-number to accept the full number. Then, I have a few pots dial-peers using destination-pattern of the full number and the translation-profile to change the full number to 2490 and send the call out one of 4 pots lines all connected to a FaxFinder Gateway.
2911 SIP CUBE:
! dial-peer voice 4567 voip description Fax Machine - 555-123-4567 destination-pattern 5551234567 session protocol sipv2 session target ipv4: <2821-ip-address> dtmf-relay sip-kpml rtp-nte codec g711ulaw fax-relay ecm disable fax-relay sg3-to-g3 fax rate 14400 no vad !
2821 Voice Gateway:
! voice translation-rule 3 rule 1 /5551234567/ /2490/ ! ! voice translation-profile 800-FAX-IN translate called 3 ! ! ! dial-peer voice 4567 voip description Incoming VoIP Dial-Peer Fax - 555-123-4567 session protocol sipv2 incoming called-number 5551234567 voice-class sip bind control source-interface GigabitEthernet0/0 voice-class sip bind media source-interface GigabitEthernet0/0 dtmf-relay sip-kpml rtp-nte codec g711ulaw fax-relay ecm disable fax-relay sg3-to-g3 fax rate 14400 no vad ! dial-peer voice 45672 pots translation-profile outgoing 800-FAX-IN destination-pattern 5551234567 port 2/0/2 ! dial-peer voice 45673 pots translation-profile outgoing 800-FAX-IN destination-pattern 5551234567 port 2/0/3 ! dial-peer voice 45674 pots translation-profile outgoing 800-FAX-IN destination-pattern 5551234567 port 2/0/4 ! dial-peer voice 45675 pots translation-profile outgoing 800-FAX-IN destination-pattern 5551234567 port 2/0/5 !
This configuration appears to be working as the Fax gateway/server is receiving faxes.
Thanks Again,
Matt
01-14-2020 07:25 PM
You need below configuration:
Inbound Dial-Peer to match 5551234567 and translation profile to translate to 2490.
! voice translation-rule 206 rule 1 /5551234567/ /2490/ ! voice translation-profile MAIN-FAX-INBOUND translate called 206 ! dial-peer voice 9000 voip description ** INBOUND CALLS FROM SERVICE PROVIDER ** translation-profile incoming MAIN-FAX-INBOUND incoming called-number 5551234567$ ++++++ add other dial peer configuration parameters depending on your setup +++++++ !
Outgoing Dial-Peer to send the call to next gateway:
! dial-peer voice 2608 voip description Fax Machine - 555-123-4567 destination-pattern 2490$ session protocol sipv2 session target ipv4: <fax-gw-ipaddr> dtmf-relay sip-kpml rtp-nte codec g711ulaw fax-relay ecm disable fax-relay sg3-to-g3 fax rate 14400 no vad !
01-15-2020 10:51 AM
Thanks Vaijanath.
2911 SIP CUBE:
2821 Voice Gateway:
Thanks Again,
Matt
