New username and password for CCM 5.0 with limited Access.
Syed Akbar Ali
I have CCM 5.0 with Administration Account . I would like to create CCM new account for new trainee engineer with limited access i.e Standard CCM Phone Administration , ccm Admin users and ccm phone Management only . like adding new  ip Phone change the existing user name and extension only.
So please advice how to create an new CCM Account with the above limited Access.
Highly apprecited for quick response.
Jaime Valencia
You configure that thru roles and groups.
User Group Configuration
The role and user group menu options in the Cisco Unified CallManager Administration User Management menu allow users with full access to configure different levels of window access for Cisco Unified CallManager administrators. Users with full access configure roles, user groups, and access privileges for roles. In general, full-access users configure the access of other users to Cisco Unified CallManager Administration.
User groups comprise lists of application users and end users. A user may belong to multiple user groups. After you add a user group, you then add users to a user group. Afterward, you may proceed to assign roles to a user group. If a user belongs to multiple user groups, the MLA permission enterprise parameter determines the effective privilege of the user.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Thanks for helpful information .
