NIM-2FSXP on ISR4321 check line on analogue phone
4qbuddy
Some help required please. I need to set up an analogue phone on a 4321, with 2 port FXS NIM installed. Its all set up (config below) but there's no dial tone, and the cable status on the voice port is 'not connected'. I've turned the rj11 cable back on its other voice port and it comes up.
[edit] the phones I am using are basic battery powered British Telecom phones. Nothing fancy
voice-port 3
 cptone GB
 timeouts call-disconnect 1
 connection plar 10901
 description *** local 10801 PLAR TO 10901 PORT 3 ***
dial-peer voice 10801 pots
 description *** 10801 LOCAL PHONE FXS 3 ***
 destination-pattern 10801
 port 3
dial-peer voice 10901 voip
 description *** 10901
 destination-pattern 10901
 session protocol sipv2
 session target ipv4:172.16.1.9
 voice-class sip bind control source-interface Loopback1
 voice-class sip bind media source-interface Loopback1
 codec g711alaw
 ip qos dscp cs3 signalling
15 Replies 15
voice-port 3
 cptone GB
 connection plar 10901 <<<<< when you lift the handset it dials, 10901.
Based on your Configuration, if you lift the handset it should ring  10901 is that working ?
Can you share "sh voice port  summary "
Response Signature
No. show voice cable-detect doesnt even show that the phone is connected. This is on two phones as well. There must be something in the config
So you mean out of all FXS port two are not detecting the cables.
I dint see any shutdown command on the shared config, But have you given shutdown commands on the port ?
The config looks good for basic calling.
There are chances, that individual port can go faulty.
try different cable, different analogue phone, re insert  the NIM card, and try a reload. if nothing  helps raise an RMA.
Response Signature
yes, not shutdown has been done
Theres just 2 routers with 1 voice card in each, with 2 ports with a phone at each end. Neither are working. I tested the cables and phones on my home pots.
Phone--[fxs]router---wan sim---router[fxs]--phone
can you share show  inventory
Remove  connection plar 10901 from port config.
Response Signature
Will do, when im on tomorrow
Make sure that the module is FXS and not FXO.
if FXO your scenario doesn’t work
Response Signature
definitely fxs. show int shows its an fxs
Please share show inventory. and voice port summary output.
Response Signature
Hi Nithin. Thanks for your time. Ive uploaded a file with the requested commands. Included is both routers
I didn't see any attachment.
Response Signature
Apologies, I added it to my original post. Ill include it here too.
4qbuddy
Might this be something to do with the pinout of the rj11 connector? UK phone to potentially a USA FXS? Im using what I think is a standard cable in the UK. As i said, the ports come up when looped back on themselves, so maybe its a crossover/straight-through type issue?
Could you do a show version and post what version of iOS you are running?
