NM-CUE can not ping tftp
Hasrat Raja
I have a NM-CUE in a 2811 router, I need to upgrade software but  I can't ping anything on lan, I can only ping router interface.
Here are some show outputs:
2811#sh interfaces service-Engine 1/0
Service-Engine1/0 is up, line protocol is up
  Hardware is I82559FE, address is 001e.7a5f.80e8 (bia 001e.7a5f.80e8)
  Interface is unnumbered. Using address of Vlan10 (10.0.8.10)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
2811#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.0.8.20 to network 0.0.0.0
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       10.0.8.0/24 is directly connected, Vlan10
S       10.0.8.11/32 is directly connected, Service-Engine1/0
S*   0.0.0.0/0 [1/0] via 10.0.8.20
hasrat
18 Replies 18
Hmm. . .Definitely sounds like a routing issue somewhere. Not sure what loopback info you're looking for.
loopback interface which shows up in sh ip route of cue:
se-10-0-8-11> sh ip route
           DEST            GATE            MASK   IFACE
       10.0.8.0         0.0.0.0   255.255.255.0   eth1
      127.0.0.0         0.0.0.0       255.0.0.0      lo
Yes, this is normal. I have a CUE that also shows a loopback interface and works properly.
Brandon
how to see the loopback information, I can't find any command to dispaly it.
