05-07-2007 08:41 AM - edited 03-14-2019 09:20 PM
What is the difference between this 2 network Modules??
Can I connect 2 VIC2-2BRI-NT/TE on a NM-HD-2V (using the NM slot) and still have the 4 slots for HWIC, WIC, VIC, or VWIC type modules on a 2821 router??
Ricardo
Solved! Go to Solution.
05-07-2007 08:55 AM
The precious "voice hardware compatibility matrix" at:
http://cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
says that you can do that.
05-07-2007 08:54 AM
HD-2V has DSPs on board. You cannot add or expand the dsps available using PVDM2s on a HD-2V module. It will take all the VICs and VWICs like the NM-HDV2 ,but no expansion on the DSP side. NM-HDV2 on the other hand is capable of expanding the number of PVDM2 chips. For the same reason you may use it for terminating vics/vwics or use as a dspfarm.
05-07-2007 08:55 AM
