NM-HDV2-1T1/E1 on a 2811
fedecotofaja
Hi All,
I have a 2811 with a NM-HDV2-1T1/E1 card. I need to know if I can divide the 30 channels from the E1 into several groups (more than two). I have been looking but I haven't found if this feature is supported on this router with this card.
Thank you all!
paolo bevilacqua
It should be possibile to do that via trunk-group timeslots under controller. Please explain why you think is necessary for you to do that as often it is also possible to solve in other ways.
